09-24-2019, 11:33 AM | #21 |
Re: 1954 Ranch Wagon Parts ID
You are quite welcome.
I think the insulator assy you are asking about is here - BM 7001670-A The complete assy is not shown (or I cannot find it) and you have to piece it together.
DIAGNOSED CDO - (OCD In Correct Alphabetical Order) Last edited by KULTULZ; 09-25-2019 at 11:06 AM. |
09-24-2019, 12:28 PM | #22 |
There is a 302/AOD in my car. What I don't like is the angle of the motor/trans and the lack of clearance at the firewall. There is a lot of room between the fan and radiator. If the motor was carbureted, it would need one of those angled spacers at the intake manifold. I have yet to take measurements of the driveshaft angle. The motor is FI and the harness may have come with original motor, however the computer part number reads manual trans. My trans has a tv cable on it. The harness was not stripped down for the basic operation of the motor only.
I would have set up the engine mounts and wiring differently. |
09-25-2019, 02:37 AM | #23 | |
Did they put a MIL (malfunction indicator lamp) on the car? Did you ever post photos of the engine conversion? The engine should sit in the cradle normally.
DIAGNOSED CDO - (OCD In Correct Alphabetical Order) |
09-25-2019, 04:23 PM | #24 |
However, what I found like : the motor alone is 150 pounds less in weight with more power. I can't remember the weight loss for trans, this set up lasts longer in miles and less trouble.. It takes a bit to get the almost 2 ton vehicle moving!! The front of the vehicle may ride a bit higher.
Hi Kultulz! There is an operational MIL, check engine light hanging just below and back of the dash. I removed the EGR, placed a cover on and a bypass for the wiring. Before installing the wire bypass, the check engine light was on. There is an OBD1, yes 1 port which I have yet to read with my purchase of a Reader OBD1. Leaving for home this weekend, will post photos of engine compartment for the above engine swap. This is the only photo of the engine compartment on my IPad here. There is room behind the motor but I'd prefer more just to find out the layout of the vacuum lines. Don't know yet what the black item is, perhaps for the fuel operating system. There are exhaust readers in the pipes. (I get 14 mpg on a good day.) Last edited by Jwawhite; 09-25-2019 at 05:22 PM. |
09-25-2019, 08:38 PM | #25 | |
It appears to be a MAP SENSOR. There should be ID Nos on the top. By any chance did you record the ECM ID NOS?
09-25-2019, 09:01 PM | #26 | |
Below is a photo of a 54 CRESTLINE which appears correct
09-26-2019, 12:25 PM | #27 |
Kultulz here's a photo of my ECM
51504bat, were you on the Force? My ECM is mounted on the passenger side wall kick area and covered by a trim panel. The side black box contains the fuses, and relay for fuel shut off. The OBD1 port is here also. |
09-26-2019, 05:07 PM | #28 |
[QUOTE=Jwawhite;1803331]Kultulz here's a photo of my ECM
51504bat, were you on the Force? CA ABC
09-26-2019, 05:45 PM | #29 |
"Don't know yet what the black item is, perhaps for the fuel operating system. There are exhaust readers in the pipes. (I get 14 mpg on a good day.) "
Jawhite, that black box is a MAP sensor as KULTULZ said. (Manifold Absolute Pressure). The nipple on it that is pointing downward, needs a vacuum hose on it from the intake manifold. With it the way it is, I would expect it's using way too much fuel. Sal |
09-26-2019, 06:16 PM | #30 |
good catch!
09-26-2019, 07:38 PM | #31 |
scicala,
I think it is hooked up correct for a mas air system. That only hooks to manifold on speed density system. |
09-27-2019, 12:15 AM | #32 | |
Having a MAF ECM, the system must be MAF and that sensor is a BAP sensor. Good Catch again.
09-27-2019, 08:46 PM | #33 | |
You might check here in this problem 1954fordclub.com There are a number of guys that have a 302 in their 54's
09-28-2019, 08:47 AM | #34 | |
SECTION 1 - Pg No. 6 and SECTION 6 - Pg No.17
10-04-2019, 11:36 AM | #35 |
51504bat here are some pics of my 302 install
10-04-2019, 04:23 PM | #36 | |
Estout81, I had a little memory hitch. Thanks for catching me. I forgot about mass air systems compared to speed density systems. I was thinking speed density system. If it has mass air, then it stays as pictured. Sal |
10-05-2019, 12:48 AM | #37 |
"5150" someone call the Po-Po
Here are some photos that may give you some insight into installation of your 302. Motor mounts, underneath car showing gap between fan and radiator, shift linkage w/o Heim joint.... space between firewall and motor, space of fan and radiator looking down at motor. |
10-05-2019, 02:50 AM | #38 | |
Now this (IMO) is the way a SBF should sit in a 54/56 cradle (minus scubby DIST).
10-06-2019, 11:57 PM | #39 |
Yes, that's the way a motor should sit in the cradle! How is the driveshaft angle to the differential?
10-07-2019, 04:15 AM | #40 | |
You know something? The way your engine was installed ... ... may have thrown off the angle you are referring to. Final engine to pinion angle may be way off.
