06-07-2015, 08:54 PM | #1 |
Is the verdict a cracked block?
Last year I had quite a setback with rust in the cylinder bores of my B engine even though the engine was drained of coolant. I removed the cylinder head, cleaned it up with a wire wheel and did the same with the bores. I cleaned up everything as well as possible. I replaced the head gasket, using Indian Head shellac on both sides of the gasket. I torqued the head several times right after getting the engine warmed up. I did a compression check and everything looked OK. I ran the car for a couple outings and it ran well. Then for the winter I fogged the motor and turned it over several times to make sure the cylinders were lubricated.
I just fixed a couple carburetor leaks, did some ignition maintenance and other minor repairs and got the car started this afternoon. I noticed the exhaust manifold gaskets had failed, so I tore it down to replace them. Water trickled out of the exhaust manifold when it was loosened. I dried it up and cleaned the surfaces to install new manifold gaskets. Water reappeared in the rear 4 ports, but not in the first two. The water sat in the port as a bead about a .25" in diameter. What's the verdict? Do I have a cracked block? I can't believe the head gasket is bad already. This is a B motor with a 6:1 Brumfield head. Any suggestions on my next steps? Thanks. |
06-07-2015, 09:24 PM | #2 |
Re: Is the verdict a cracked block?
Are the 2 steam holes in the middle of the block deck plugged? If not they will leak when using a Model A head or gasket.
http://www.model-a-ford-4bangers.com/ |
06-07-2015, 10:05 PM | #3 |
B motors are known to crack around the valves. Seems Henry took a good thing, the A block and stuffed it up. I suspect he was trying to save a few cents on each block by cutting them short on cast iron, it was depression time after all.
06-07-2015, 10:12 PM | #4 |
The exhaust ports for the middle two cylinders have very thin castings. Look for pinholes appearing in the port pockets and that is where the water is coming from. I have a block with the same symptoms and condition and am curious if the block can be saved by hogging out the castling and pressing in a sleeve.
06-08-2015, 04:22 AM | #5 |
It is possible the head gasket has failed and only inspection confirm that
as said in other posts B model blocks and heads cracking is common and they can be repaired A pressure test is the easiest way to locate the source of the leak |
06-08-2015, 10:29 AM | #6 |
Bob Bidonde |
06-08-2015, 11:11 AM | #7 |
The steam holes were plugged. I am operating with the theory that due to the head gasket replacement last summer and it only being on the road once since then that it is not the head gasket. I like the idea of the pressure test and also the steam test. Thanks everyone for your observations and suggestions.
06-09-2015, 11:29 AM | #8 |
Any other thoughts? Otherwise I think I will start with the pressure test.
