03-25-2011, 10:46 PM | #41 |
Re: speed parts on the banger
My opinion:
Forget the finned bling. Honor the car. Keep it real. |
03-26-2011, 11:52 AM | #42 |
03-26-2011, 12:06 PM | #43 |
Yes!! It does.
Paul in CT |
03-26-2011, 12:10 PM | #44 |
I believe those tires were made relatively recently, but that's just nit picking. That is a beautiful coupe!
03-26-2011, 12:30 PM | #45 |
Here's an original pre war CRAGAR head and a Stromberg-Bendix downdraft available in 1931.
03-26-2011, 01:10 PM | #46 | |
03-26-2011, 01:15 PM | #47 |
03-28-2011, 09:22 PM | #48 |
Thanks for the compliments! And yes, those tires are newer! LOL Everything on the car is bolt on, can go back to stock very easily. I do have a completely stock 31 A pickup that will never be modified. I also drive the snot out of that coupe, way more fun than any vehicle I own. I have had the die hard restorers compliment the way I have done that car. I feel as though I have respected the car.
1927 T, 1930 A coupe, 1929 A Roadster, 1933 Dodge pickup, 1935 5 window coupe |
03-29-2011, 09:36 PM | #49 |
https://www.youtube.com/watch?v=fujo5...layer_embedded
Some good pre-war hot rod photos and a good old song to go with them. Last edited by rmak; 03-29-2011 at 09:53 PM. |
03-29-2011, 11:15 PM | #50 | |
very nice |
02-02-2013, 01:42 AM | #51 |
i have a stock 28 coupe and would like to get the same look you did lowbuckboz,can you send me some info on parts you used.
02-02-2013, 02:32 AM | #52 |
When you get to the point where your A can cruise 90, consider getting some fins from a
'59 Caddy and welding them to the rear fenders. |
02-02-2013, 02:43 PM | #53 |
02-02-2013, 06:04 PM | #54 |
Here is my Trojan dual updraft setup on our roadster. Its a cast iron period correct speed part.
02-04-2013, 01:15 AM | #55 |
Both my 30 coupe & 31 s/w sedan run 33 B engines & Columbia OD,s.The coupe has a 5.9 BF head & the sedan will have a 5.5 head.Also using Teds Floaters for added stopping power.Never drilled a single hole in the mods ,so it could be changed back to stock in a week-end,but not as long as I own the cars.Its nice to be able to cruise at 60 on busy hiways at low rpm with less change of getting rear ended.
03-14-2013, 06:22 PM | #56 |
my 28 coupe is all stock,would like to add duel carb downdraft intake.will this be a bolt-on or i will have to make some engine up-grades.i have a zepher duel carb intake.
03-14-2013, 07:33 PM | #57 |
Try one of these; single carb, but it's 2-barrel. And it's completely bolt-on.
03-15-2013, 10:19 AM | #58 |
[QUOTE=Mike V. Florida;179224]Drop in a small block V8, dropped axle, juice brakes, od tranny.....
Seriously, the first thing you need to decide is what do you want from your Model A? This site was designed by it's owner to lean way over to the restoration side and his site HAMB is designed for the modified side.
If it would have been a snake it would have bit ya! i can't spell my way out of a paper bag! |
03-15-2013, 09:50 PM | #59 |
i have a zepher 2 carb intake,will this work on my stock engine and what carbs to use.
03-15-2013, 10:00 PM | #60 | |
On a stock engine you would do best with the 81's. Even better is use 3 bolt to 2 bolt adapters and use the single throat Holley's from a Ford 6. |
