12-26-2017, 08:11 AM | #21 |
Re: Corn Head Grease Use
12-26-2017, 02:22 PM | #22 | |
https://youtu.be/7zNhli-J0Gk |
12-26-2017, 09:49 PM | #23 |
I used JD cornhead grease in my fire pump grease fittings and reduced the noise coming from the pump. Also filled the nearly empty steering box with it.
12-26-2017, 10:12 PM | #24 |
I've got it in the 37 Hudson steering box in my deuce pu and it works fine, steers easy and no leaks. Also putting it in all the gear boxes in my center pivot irrigation systems. 24 per pivot to prevent leaks and gear box failure. Dealer says it virtually stops box failure and at 850.00 a piece that's a big deal. Just realized I'm being a little redundant as I said the same in the post on spring grease
12-26-2017, 10:59 PM | #25 |
Silly question I guess, but how do you get the old lubricant out of a steering box to put the new lubricant in?
12-26-2017, 11:02 PM | #26 |
06-23-2018, 06:41 PM | #27 |
Hi Phil
Where in NZ did you find the JD Corn Head grease? Thks Dave Young |
06-23-2018, 08:56 PM | #28 |
06-23-2018, 10:14 PM | #29 | |
Were there Nay-Sayers? I use it in the "clamshell" torque tube u-joint also. |
06-23-2018, 11:15 PM | #30 | |
Think I had a box sent by amazon or ebay. JD Implement is probably cheaper. https://www.amazon.com/John-Deere-Co...ornhead+grease https://www.ebay.com/sch/i.html?_fro...rease&_sacat=0 |
06-23-2018, 11:44 PM | #31 |
Problem is that us kiwis are not allowed to import petroleum based materials. We can't get Marvel mystery oil here, and cannot import it.
At least our gas, whilst still crap, is better than you guys in the States get!!
06-23-2018, 11:54 PM | #32 |
That's a real thing?
06-24-2018, 03:13 AM | #33 |
06-24-2018, 03:23 AM | #34 |
any one in Australia know if JD grease is available here and who has it or if one of our oil company's make an equivalent
06-24-2018, 05:27 AM | #35 |
No corn head grease where i live, but i was able to get this penrite stuff that appears similar.
<Link> This is how we roll<Link> "I'm Convinced that no one really reads posts anymore; they just fabricate what they think the post says then ramble on about red herrings."--Bob Outcasts rules of old cars #1 Fun is imperative, mainstream is overrated #2 If they think it is impossible, prove them wrong #3 If the science says it impossible you are not being creative enough. #4 No shame in recreating something you never had #5 If it were not for the law & physics you would be unstoppable |
06-24-2018, 06:22 AM | #36 |
Aussie Merc,
I live close to a wheat growing area, no were close to corn crops, and a John Deere agent down there had two cartridges so I snapped them up. I used one and sold the other to a mate. Like the others have said it works a treat. I can ask my JD agent if they can get some if you like. I only found mine by asking a mobile JD mechanic if he had seen any in his travels and as luck would have it he did. PM me if you need any help. Regards,Gary |
06-24-2018, 07:40 AM | #37 |
Amazon sells it: https://www.amazon.com/s/ref=nb_sb_s...d=PIGG9NN1KNJ1
08-11-2021, 11:10 AM | #38 |
Anybody have comments on Cotton Picker Spindle Grease from Tractor Supply?
The Cotton Picker grease was reccomended over the Cord Head Grease for my '37 Hudson steering box. Thanks |
08-11-2021, 12:54 PM | #39 |
What you want to do in situations like this, is drill down a bit into what the Ford specifications for a particular lubricant in a particular application are (or were), the numbers or names change. Most of us are familiar with NLGI #2 chassis grease used in drive shaft zerks and kingpins. Often this is the only grade available at retail outlets. But there are other grades of grease available. A "00" grade or "self leveling" grease is just about perfect for manual steering gearboxes.
Only the names are changed, to protect the innocent, something like that. Marketing and brand names just confuse people, or make them spend 10 times what they need to. |
08-11-2021, 02:24 PM | #40 |
The "OO" liquid grease, right? I have both corn head and the cotton picker spindle grease, so I'm curious if anyone has experimented with the two as well.
