04-30-2018, 09:44 AM | #1 |
1948 pickup 3 speed transmission
What a 1948 pickup 3 speed transmission core worth I know the top are worth some good money it is a open drive the guy says the cluster gear has a chip in a tooth
04-30-2018, 04:07 PM | #2 |
Re: 1948 pickup 3 speed transmission
I'd say $500 less the cost of a new cluster gear!!
04-30-2018, 06:30 PM | #3 |
It has value but the cluster is one of the expensive parts. I'd worry more about what condition the case is in when looking for a Ford light duty 3-speed. No cracks around the counter shaft bore in front and a decent thrust face at the back. If the case is bad, there are only a few good parts left it there. The side shifters can still be had for a decent price and the guts will go right in that case if they are all still good. The top is a good one as long as it isn't too worn and the 2nd/3rd shift fork is in good condition. A lot of folks are looking for the closed drive type main shaft unless they are putting it back in a pickup.
04-30-2018, 07:20 PM | #4 |
It is a top shifter
06-19-2018, 06:48 PM | #5 |
Pictures of it
06-19-2018, 07:18 PM | #6 |
"whatever works!" |
