Old 03-10-2018, 10:56 AM   #1
37don
Default Gas line
How far should the gas line from the gas tank go into the tank? On my 37 sdn the line goes in about 2.5”. Should it go in to the bottom of the tank just off the bottom? Thanks,Don
37don is offline   Reply With Quote
Old 03-10-2018, 11:05 AM   #2
Kube
Kube's Avatar
Default Re: Gas line
About 1/2" past the ferrule is more than enough.
Old 03-10-2018, 02:23 PM   #3
JSeery
JSeery's Avatar
Is the fitting in the stock location on the bottom of the tank? Almost sounds like your talking about a fitting on the top of the tank (aftermarket tank). If that is the case, the line needs to go to the bottom of the tank.
Old 03-10-2018, 03:00 PM   #4
Kube
Kube's Avatar
'37 Ford tank has the outlet on the side of the tank - front - about 5" from the bottom. The line does not need to extend anymore than 1/2" in to the tank.
Old 03-10-2018, 03:20 PM   #5
JSeery
JSeery's Avatar
Well, that would make a difference! For some reason I was thinking of a later tank!
Old 03-10-2018, 09:17 PM   #6
37don
Yes Kube is right. Is there a pickup pipe that extends to the bottom of the tank?
Old 03-11-2018, 08:22 AM   #7
Kube
Kube's Avatar
There is. It is integral of the tank. You should be able to see at minimum, part of it, by peering through the sending unit hole.
Old 03-11-2018, 08:38 AM   #8
rotorwrench
rotorwrench's Avatar
Most internal tank pick up tubes in the more modern Fords have this feature. They do act as a stand pipe but only about the diameter of the tube off the bottom. It's important to leave a space for water and other heavier than fuel debris to settle.
Aircraft tanks have a sump on the bottom with a water drain valve but automobiles seldom have a feature like this, if ever.
Old 03-11-2018, 12:18 PM   #9
George/Maine
George/Maine's Avatar
I think the aftermarket tanks the tube has to go near bottom of tank.
There has been problem with 1/2 tank of gas and no gas to start.
George/Maine is offline   Reply With Quote
