01-01-1970, 12:00 AM | #1 |
Guest
Posts: n/a
CLUTCH
Is it ok to put the flywheel and clutch from a pickup ( 11" ), into a 54 Ford car with original 3sp overdrive ? If there are no bad side effects,I would like to use these parts to save having to buy others. Thanks, bill <table><tr><td><font face="arial"> |
01-01-1970, 12:00 AM | #2 |
Guest
Posts: n/a
Re: CLUTCH
10 1/2 or 11 inch will work. Some flywheels are drilled for both. Jack <table><tr><td><font face="arial"> |
01-01-1970, 12:00 AM | #3 |
Guest
Posts: n/a
Re: CLUTCH
the 11" well work but you need to change the flywheel. <table><tr><td><font face="arial"> |
01-01-1970, 12:00 AM | #4 |
Guest
Posts: n/a
Re: CLUTCH
Somewhere in those years pickups still used a 1 3/8" dia. input shaft and cars used a 1 1/16" dia. shaft. I don't remember when they changed but check this too. <table><tr><td><font face="arial"> |
