02-12-2020, 10:43 PM | #1 |
Electric fuel pumps...
I have an old Corvette that I drive to a cruise night on Fridays during the warm weather. When I bring it home and park it in the garage, it stinks from the gas in the carburetor evaporating. And then, the next week, I have to crank it until it pumps gas back up to the carb. Does anyone using an electric pump shut the gas off and let the carb run dry to shut the engine off?
Don't never get rid of nuthin! |
02-13-2020, 12:12 PM | #2 |
Re: Electric fuel pumps...
Hi Pete
My 39 (w/ dual 94a) only has an electric pump. I never needed to run carb dry. I do not have any smell of gas in garage. I would check for a leak. Maybe around fuel filter?
Thanks Andy 1952 F1 |
02-13-2020, 01:14 PM | #3 |
You didn't mention what year or motor. My "61" with the tank behind the seat was leaking around the the old deteriorated rubber hoses and would smell in the cockpit.
Yours has a problem somewhere. Installing an electric pump if it does omit the problem it is not fixing the problem. I would search the reason for the gas smell and correct it. Last edited by solidaxle; 02-13-2020 at 04:42 PM. |
02-13-2020, 01:20 PM | #4 |
Not that it's a big deal and we are all car guys trying to help each other, you may want to post your question at a different site.
02-13-2020, 02:13 PM | #5 |
A simple shutoff valve between the mechanical pump & carb will do the job. No electric pump needed. Of course, you'd need to open the hood to turn valve while the car's idling to run it dry. Then turn it back on again for the next cruise. Jack E/NJ
02-13-2020, 02:32 PM | #6 |
02-13-2020, 05:11 PM | #7 |
I have experienced that smell in the garage after shut-down, with my SBC with Edlebrock carb on aluminum intake. I added a phenolic spacer under the carb. Reduced the smell quite a bit. The phenolic spacer reduces the amount of heat-soak transfer into the carb, which reduces fuel evaporation at the carb.
02-13-2020, 05:35 PM | #8 |
The OP all have good ideas but you might try just opening the hood and letting it sit for the night after cruise to let the heat buildup out. Painless experiment. Just a thought.
02-14-2020, 10:06 AM | #9 |
I had a Holley 390 on an Offy intake on my '39, and electric fuel pump only. I also had a fuel pressure gauge inside the car. Yes, I know that's a no no, but with stainless AN plumbing, I never had a problem. I ran the pump until I got 4 lbs of fuel pressure and then hit the starter. On shut down, I turned off the pump and waited until the pressure dropped to zero. Never had any gas smell.
That said, agree with the poster who said something is wrong and need to fix the leak/evaporation issue. Am working on this issue on my '47 with help from Charlie ny! |
02-14-2020, 12:42 PM | #10 | |
If you detect a strong gas smell, open the hood so the fuel-air mixture is diluted and things cool down. |
02-14-2020, 12:46 PM | #11 |
I also agree that there is something wrong. This is a common problem brought up on the Corvette forums, but I have never seen it with my '67. I have spent a ton of time on the carb in that car, making sure all surfaces are dead flat and everything else is up to snuff.
I bought my "surface plate" just to work on this carburetor. |
02-14-2020, 05:58 PM | #12 | |
02-14-2020, 07:22 PM | #13 |
Ggmac>>>Is it a quadrajet in the corvette ? They had a problem with a plug leaking internal . The 1st GM fix for it was a small sponge .>>>
Hmmm? A small sponge eh? Sounds kinda iffy. What was their 2nd fix? Jack E/NJ |
02-14-2020, 07:52 PM | #14 |
02-14-2020, 08:44 PM | #15 | |
Yeah, I do just that...run the carb till engine stops. That being said, sounds like you have a fuel leak that should get your attention...before something bad happens. Luck to you ! |
02-16-2020, 07:47 AM | #16 |
It's a WCFB Carter. Stock base engine in a '63. When I bring it out of storage, I'll have go looking for a leak. Thanks all!!
