Old 01-20-2020, 02:14 AM   #1
56yblock
56yblock's Avatar
Default thermostat
hello everybody,
what's the thermostat that you put on your y block ford?
56yblock is offline   Reply With Quote
Old 01-20-2020, 08:16 AM   #2
reddog565
Default Re: thermostat
I have a " stock rebuilt, with trips".
It has an electric fan. So, I run a
160 degree thermostat..
reddog565 is offline   Reply With Quote
Old 01-20-2020, 01:46 PM   #3
56yblock
56yblock's Avatar
i have 195 degree with stock rebuild radiator, i think is too hot ....
Old 01-20-2020, 03:00 PM   #4
Hot Rod Reverend
Hot Rod Reverend's Avatar
For what it's worth, I have a 195 Fahrenheit thermostat and I am very happy with it, come summer or winter driving. It's just my opinion but I believe that Y blocks run the best on the hot side of life. It especially helps the keep the sludge out of the crankcase.
Lancaster, California
Visit hotrodreverend.com to view hundreds of pictures and videos of the build of the 1955 Ford Club Sedan!
Hot Rod Reverend is offline   Reply With Quote
Old 01-20-2020, 05:07 PM   #5
Daves55Sedan
Daves55Sedan's Avatar
160 and 180 degree farenheit thermostats are commonly available. I have always used the 160 degree, because ignition condensers tend to fail if it gets too hot. Have not had any trouble in winter yet, but several times during summer in ambient temperatures above 90 degrees.
Make sure you install the thermostat in the proper direction. It is stamped on one side "this side toward engine".
Old 01-20-2020, 07:08 PM   #6
dmsfrr
dmsfrr's Avatar
If you'd like a little more water flow there are a couple thermostats with a larger opening.
Mr. Gasket or NAPA # 6 sounds familiar, among other brands.
Here's a link to an example but (depending on your location) you should be able to find one like it at a local auto parts store for half the price of this one.
https://www.classictbird.com/Thermostat-Large-Opening-170-Degrees/productinfo/8575C/
There is a possible installation complication with '57 4bbl intake manifolds that can easily be solved...
https://www.ctci.org/1957-thermostat/
Old 01-21-2020, 12:53 AM   #7
56yblock
56yblock's Avatar
i have these ones, the first pic is 195 degree with big capacity and other one is 160 with alternative,what is the best?
Old 01-26-2020, 05:41 AM   #8
56yblock
56yblock's Avatar
i've put the 160 degree it's seems correct and works good ...
