11-16-2019, 07:00 PM | #1 |
39 coupe fuel tank
Hi
I’m thinking my original fuel tank is needing to be replaced. I’ll keep my stock sending unit. Where have you found to be a good supplier? Both in quality, fit and price. Car is not concourse, currently. But if I ever sold it a person could take it to that level. All changes I’ve made are bolt on.
Thanks Andy 1952 F1 Last edited by adileo; 11-16-2019 at 08:02 PM. |
11-16-2019, 08:24 PM | #2 |
Re: 39 coupe fuel tank
Before you buy a new tank, remove the old one and really give it a good inspection. It might just need to be cleaned. Original tanks hold 14 gallons. You can also get repro tanks that hold 16 gallons. If you have dual exhaust stick with original tank for better tail pipe clearance. Also, make sure your repro tank will accept OEM 6V sending unit. I believe repro tanks have to be made to new government safety standards where the tank fuel outlet is no longer on the bottom like the original. I found that out with the 40 tank I bought from TANKS Inc. Plus, make sure you new tank has a drain plug and proper cage nuts for mounting.My plastic TANKS Inc. tank did not. I am not familiar with DRAKE tanks.
11-16-2019, 08:34 PM | #3 |
Thanks Andy 1952 F1 |
