Old 06-01-2010, 07:31 AM   #1
ridgy
Default "A" axle's
Are 28/29 and 30/31 front axle's identical?
ridgy is offline   Reply With Quote
Old 06-01-2010, 07:43 AM   #2
Aerocraft
Aerocraft's Avatar
Default Re: "A" axle's
Initially, all axles had a large script on the front right and left rear side of the web. early in 1928, a smaller script was used. From mid 1929 on there was no script. Other than the script, the axles were the same although there were changes in the attaching parts. Gar Williams
Aerocraft is offline   Reply With Quote
Old 06-01-2010, 09:59 AM   #3
Kevin in NJ
Slight differences from the JS point of view.
There will be some with AA and others with EE. That is just the type of steel, not for a AA truck.
http://home.comcast.net/~68c/Front_axle_straightening.htm
Make sure the king pin fits tight in the end. Look for signs of heating to remove the perch. Look for signs the perch was loose and that area is wore in too much.
Old 06-01-2010, 06:15 PM   #4
ridgy
Thanks guys.Handy link Kevin,thanks
Old 06-02-2010, 02:36 AM   #5
Tudortomnz
Tudortomnz's Avatar
Ridgy [didge?]
Hey,my '29 axle has Ford script stamped 'upside down'. Wonder whether because it was destined for 'Down Under' ???
Tomnz
Tudortomnz is offline   Reply With Quote
