10-01-2014, 09:44 PM | #1 |
crank packing
going to return the oil pan and its been a long long time since initialling front packing and how to cut excess packing top and bottom and does the pan up first then cam cover second? thanks 40 years since I worked on vintage stuff.
10-01-2014, 09:55 PM | #2 |
Re: crank packing
The packing if I am thinking it is the white rope seal shouldn't be cut if it is the right part for a model A. It should extend some for compression. it needs to be seated firmly in it's channel this can be done with a light hammer and a large socket on its curve. You might be able to verify all this with the parts supplier.
10-02-2014, 09:58 AM | #3 |
Re: crank packing
I think that you have to soak it in oil before installing it. I think.
Mike
1930 TownSedan (Briggs) 1957 Country Sedan |
10-02-2014, 11:51 AM | #4 | |
Re: crank packing
Bill W.
