06-04-2013, 06:22 PM | #1 |
How to hide finishing nails on upholstery ?
I just installed an interior kit on my S/W, everything came out great but the finishing nails holding the body panels on are still showing. The instructions with the kit were very vague on the subject. Anyone have any tips ?
Thanks for reading
1931 Slant Windshield fordor |
06-04-2013, 06:29 PM | #2 |
Re: How to hide finishing nails on upholstery ?
Depends on whether you used "finishing nails" or brads. Also depends on how old (hard) your wood was. On old wood, we often find ourselves using a pin-drill to make a pilot first where the brad can be sunk down into the fabric. A small pin punch with a small convex shape on the end is great for setting the brad.
06-04-2013, 07:08 PM | #3 |
You can use a sewing needle to pull the fabric around the head of the brad out and over the brad.
06-04-2013, 09:40 PM | #4 |
I "seat" the nails with a wood or plastic dowel, so as NOT to drive them through the cardboard panel. Then just "pluck" the material over the nail head with a large needle. I bought some really tiny brads that are like finishing nails.
Bill W.
06-04-2013, 09:59 PM | #5 |
Ok tried the needle idea, and it worked great, I was able to get the material over the nail head. Unfortunatly on the center door post, which for some reason has a thick pad of foam in between the material and panel, the nail head doesnt want to go under the foam. Im try to do this gingerly without making the hole large and noticable. The way it is now the nails arent visible yet because the foam is depressed by the head, you can see a dent where every nail is. i guess I'll keep at it.
06-04-2013, 10:08 PM | #6 | |
06-05-2013, 01:25 AM | #7 |
Additional wood tips to Bill's #6 reply above:
1. When using brads and/or finishing nails as drill bits, always snip off the larger diameter heads so they remain straight & spin concentrically when placed in a drill chuck in lieu of wobbling when rotating. 2. Also if providing wood screws in tough Model A hard wood, they are much easier to turn if one rubs the threads with "Chap-stick" -- also easy to remove later. 3. If one is providing bolts through wood in humid areas, or wet areas or subject to wet conditions, such as Model A body blocks, one can prevent shanks of bolts adjacent to wet wood from rusting by painting shanks with very fast drying finger nail polish. |
06-05-2013, 02:57 AM | #8 | |
Bill,
One unfortunate word in a single post should not spark off a reaction like this. To me, Marco has been one of the most valuable and helpful posters on this board ever, and I am overjoyed to see that he is back posting. Please do not give him any reason to stay out. Quote:
06-05-2013, 06:16 AM | #9 | |
Most of us would agree that Marco has walked the walk and has earned the right to speak of his experiences. In my opinion Marco is arguably the best Model A upholsterer in the country, and has given WAY more back to the hobby here than he has ever taken. My opinion too is Bill (or whomever this fictitious 'Dog' or 'Buster' is) should have never even written such an disrespectful comment, ...even if he did feel that way. Thanks for posting again Marco!! |
06-05-2013, 09:52 AM | #10 |
Ok I'm kind of embarrassed to say, but its a cartouche kit.... I know, I know.. But my budget just got eaten up making the car roadworthy, since its a driver I had to cut costs somewhere.
06-05-2013, 10:01 AM | #11 | |
my seats are worn out and door panels, the worst part is it never gets driven much Last edited by Mitch//pa; 06-05-2013 at 10:08 AM. |
06-05-2013, 10:10 AM | #12 |
I installed a cartouche kit in a 31 Tudor and found that the cardboard backing of the panels was very hard and the heads on the finishing nails were bigger than the originals. Had a very hard time driving them in far enough into the cardboard to pull the fabric over the heads. Although the fabric quality was not as good as it could have been, it's held up well for 3 years so far.
06-05-2013, 10:18 AM | #13 |
OK....so we can all learn...are there any photos of what the problem is
and how to correctly do this....please. Thank you.. |
06-05-2013, 10:24 AM | #14 |
My problem was because the upper cartouche panels had no padding between the cardboard and the fabric. I didn't have a problem with lower panels that were padded. I was able to pull the fabric over the nail head.
06-05-2013, 10:28 AM | #15 | |
06-05-2013, 10:35 AM | #16 |
I quess I missed Marcos post before he deleted it but Bill,
Marco is one of god's gifts to the Restoration World & he does know how to do everything SO perfectly when it comes to restorations!! He, along with the other god's gifts to the hobby, literally wrote the book on judging what is right and wrong.
06-05-2013, 10:38 AM | #17 |
Back to the original question...
I second the 'use a sewing needle' approach to lift the upholstery over the head of the fastener. In 1979, when I installed the upholstery kit in my coupe, I used a fairly large upholstery needle (used for carpet sewing). I found this gave better control over what I was doing. Just for a data point (and admittedly off-topic) here's the cost of the upholstery kit on October 10, 1978, from Carter's Cut & Cover Shop on East 6th Street in Beardstown IL. I don't know what happened to Carter's but I have been very satisfied with the quality of their product in the intervening 34+ years: $350.00 Complete Mohair Upholstery Kit (including headliner) $25.00 Brown Floor Carpet $15.00 Rumble Seat Floor Carpet $95.00 Rumble Seat Upholstery $24.00 Roof Cover Kit (did not include - as I recall - the chicken wire) n/c Side (kick) Panels (cab and rumble seat areas, including seat-back) -------- $509.00 $24.80 Shipping (Illinois to Idaho) -------- $533.80 Total cost Times have changed...
Skip Keyser Napa Valley A's Olympic Vintage Auto Club (1980-1982) MARC of San Diego (1977-1978) MAFCA (since 1978) MARC (since 1977) ---------- Model A owners belong in their Model A’s; Model A’s belong on the road. |
06-05-2013, 10:48 AM | #18 |
CHRIST.....I don't own a closed car...and I'm trying too learn something!
I'm now pissed off..... |
06-05-2013, 11:14 AM | #19 | |
here is my problem fabric wear out on the seat bottoms and door panels Last edited by Mitch//pa; 06-05-2013 at 11:23 AM. |
06-05-2013, 11:39 AM | #20 |
I agree with eystein, Brent, and Mike V. If Marco is willing to spend his time posting to try and help someone and share his knowledge and expertise, please don't attack him! He's one of the most knowledgeable folks in the hobby and some of us would like to benefit from what he has to say!
