06-11-2019, 02:39 PM | #1 |
32 juice brakes
Just asking if there is a way to fit juice brakes 32 spindles without using the spacer ring ? I did ask Boling Brothers sometime ago and they were out of drums for their kit at the time ,so I waited till they were in stock, now they are out of hubs.
Someone had fitted juice brakes to our 32 at some time but we found the outer bearing had spun on the spindle ,so the bearing could not sit tight on the spindle now and there was always some wheel wobble no matter how tight the spindle nut was. Possibly due to the spacer pushing the bearing out some from the original machined surface , but cant say for sure on that one. Last edited by my4dv8; 06-11-2019 at 03:08 PM. |
06-11-2019, 04:27 PM | #2 |
Re: 32 juice brakes
Use later spindles. '37-'48 work best and will bolt on.
1921 Runabout 1930 Tudor Early 1930 AA Speed costs money. How fast do you want to go? |
06-11-2019, 05:13 PM | #3 |
Re: 32 juice brakes
Yes , but then I loose the top 32 steering arm and the spindle height is slightly different.
I do not want a bolt on top steering arm . I would prefer backing plates that accept the 3/8 bolts . |
06-12-2019, 08:07 AM | #4 |
Re: 32 juice brakes
If you go with Boling Brothers I think they will provide the backing plates with the small pattern,s?? Early V8 Garage also makes an adapter plate kit that you can use the early spindle and Ford brakes. They also are dealers for Boling Brothers. Here is the number for them. 626 338 228 in W Covina CA
06-12-2019, 04:48 PM | #5 |
Re: 32 juice brakes
Original '39 & '40 Lincoln Zephyr are a virtual bolt on, SLIGHT modification to the spindle.
Tom |
06-12-2019, 05:38 PM | #6 |
Re: 32 juice brakes
Though finding a set may be an issue , and finding some that are still serviceable too. The last time we were in Imperial MO we called into see Kurt McCormick . |
06-12-2019, 06:28 PM | #7 |
Re: 32 juice brakes
Bob Wilson make direct fit brakes for 32 spindles. The hubs and drums could come from Speedway.
I used that combo but with 40 hubs. |
06-12-2019, 09:11 PM | #8 |
Re: 32 juice brakes
Used and would recommend Early V8 Garage. QUALITY kit with easy installation.
06-13-2019, 09:09 AM | #9 |
Re: 32 juice brakes
No matter what juice brakes you choose; later hubs are used which require the inner bearing spacer.
If you want to update from the Lockheed to Bendix brakes and retain the early spindle pattern; Boling Bros has their Lincoln style brakes available with the small pilot hole and 3/8" bolts. Their drums can be used with your existing hubs if they are the inside mount style. But; it sounds like you really need to replace the damaged spindle as part of any change. |
06-13-2019, 02:29 PM | #10 |
Re: 32 juice brakes
Thanks Rich. That’s the answer I need. I do have new (to Me) 32 spindles. Will get new inner bearing spacers from a trusted source, probably like Dennis Lacy.
It sounds like I can use my hubs that are on the 32 as they are inside mount and Boling bros backing plates and drums will all match up, and use their 3/8 bolt pattern backing plates. I would have fitted some F100 brakes I have ,but they wont accept 32 wire wheels. Hence the thoughts to go the Boling way with the stepped drum. |
06-13-2019, 03:08 PM | #11 |
Re: 32 juice brakes
06-14-2019, 07:15 PM | #12 |
Re: 32 juice brakes
I sometimes wonder why you would go to all the trouble putting on Hyd. Brakes, when the suspension system is so antiquated. Probably a stronger engine as well I realize that this improves the safely of stopping, but the ride and handling qualities make it less safe.. BY adding cross steering that would improve it as well as as ofter spring and shock as well. All this and many other modifications can be made and unless your building a muse-me piece a more valuable car. I recently had a ride in an early 52 ford PU wit a P/M front suspension and it was like a modern car. That might be extreme. I like to keep these old cars on the road as a daily driver at the least amount of cash .
06-14-2019, 09:25 PM | #13 |
Re: 32 juice brakes
If you are going to the "juice" / hydraulic set up -- I have BRAND NEW --
The master cylinder, the wheel cylinders, the ++ Asbestos ++ brake shoes ( both 1939 - 1941 and the 1942 - 1948 ) , the brake hoses, and the wheel bearings and seals.... If you need me, Always best to simply call me -- Craig -- 516 - 485 - 1935..... |
06-17-2019, 09:55 PM | #14 |
Re: 32 juice brakes
Boling Bros makes a direct bolt on backing plate for the 32 spindle that does not need the large spacer ring but you still need the small spacer ring for the hub. I have a set on my 32 PU with 32 spindles and they work great. I've sold several of their setups to customers with no problems. You still need to do a little clearance grinding on the top of the spindle but it's minimal.
06-17-2019, 10:11 PM | #15 |
Re: 32 juice brakes
Thanks Gary. So you are saying I can use my 40 type hubs with their 32 small 3/8 bolt backing plates along with their drums? I like the bolt on deal as down under we are not allowed to weld or slot the backing plates.
06-18-2019, 07:00 AM | #16 |
Re: 32 juice brakes
Yes my4dv8 you can " .... use my 40 type hubs with their 32 small 3/8 bolt backing plates along with their drums?" This is the setup I have on my 32. Here is the link on their site:
http://www.bolingbrothers.com/1928-1...late-assembly/ |
06-18-2019, 03:22 PM | #17 |
Re: 32 juice brakes
Confirmed with Boling Bros the 40 hubs with the small spacer ring on the 32 spindles. Using their backing plates and drums.
06-20-2019, 08:45 PM | #18 | |
Re: 32 juice brakes
06-20-2019, 09:21 PM | #19 |
Re: 32 juice brakes
I used the kingpin kit from Dennis Lacy's Early V8 Garage.
06-21-2019, 12:45 AM | #20 |
Re: 32 juice brakes
Does this kingpin kit as supplied comprise of '37 kingpins installed upside down and thrust washers [not thrust bearings] installed between top of axle and bottom of top yoke on the stub axle?
