08-28-2013, 10:26 AM | #1 |
1946 ford super deluxe
Alright guys I am back. I got my old 46 Ford running great. Cooling fine, after I deleted the high dollar fan shroud and air conditioning condenser. Car runs 180, 185 at 70 mph.
Question: Got a 355 gear 5 speed overdrive 59 AB motor 2-97 dueses running off 1-97 carb. what should be gas mileage, getting 11 mpg now? Do you think that I should get more, if I run 2 not a hot rod motor, small cam alum heads, that is it nothing fancy.. Just a driver.. |
08-28-2013, 11:05 AM | #2 |
Re: 1946 ford super deluxe
Are you saying you are running just one carb on a dual carb manifold? Can't help thinking it would be better with two. That's pretty tall geared, 3:55's and an overdrive. The car isn't very aerodynamic, it will be pretty thirsty at 70.
I will watch with interest what others say, I just wanted to clarify the carb situation. Mart. |
08-28-2013, 12:28 PM | #3 |
the plugs look great not lean
08-28-2013, 01:11 PM | #4 |
I just went through the exercise with "Uncle Max" Musgrove (the Stromberg man) on my plugs and the mileage & high speed jets size. I am getting 14 to 15 MPG with 2-97 carbs, mild cam, Offy heads and C-4 automatic. Mildly sooty on the edge of the plug, but light brown on the electrode and ceramic. Max felt that my mileage was normal with .043 high speed jets and the plugs look fine, so I am going to stop looking for trouble where there isn't any.
08-28-2013, 01:29 PM | #5 |
Chris what jet size or same in both what linage or you running i have one carb. Block off
08-28-2013, 01:33 PM | #6 | |
08-28-2013, 01:37 PM | #7 |
Walt what do you think i need to do
