Old 08-06-2018, 06:18 PM   #1
Ian in Mississauga
Default Oiling springs
I just put good rebuilt shocks on the front of my car and then oiled the spring with oil from the crankcase. A friend questioned my choice of oil. I thought I read that here on fordbarn but now I can't find it. Did I just screw up?
Ian in Mississauga is offline   Reply With Quote
Old 08-06-2018, 06:22 PM   #2
Synchro909
Synchro909's Avatar
Default Re: Oiling springs
No, any old oil lubricates better than rust. Some people, myself included have used all sorts of fancy stuff but they all do the same thing.
Drive on and enjoy your car, I say.
The only downside to using a wet lubricant is that dirt will stick to it. I have fitted covers to the springs on my ost used cars.
Old 08-06-2018, 08:42 PM   #3
Hoogah
Hoogah's Avatar
Synchro & Ian, how did you apply the oil to springs in situ? Does it draw itself into the gaps by capillary action?
Hoogah is offline   Reply With Quote
Old 08-06-2018, 08:48 PM   #4
Synchro909
Synchro909's Avatar
I made myself a hardened "spike" like a hollow screw driver and a grease nipple on the side. The spike ius driven in between the leaves and oil or grease pumped in. Even an ordinary screw driver would open the leaves enough to squirt in some oil, I think. It will work its way along the leaves as you go.
Old 08-06-2018, 10:43 PM   #5
Tacoma Bob
Tacoma Bob's Avatar
Kroil has a product that is designed to travel horizontally between the leaves.
Tacoma Bob is offline   Reply With Quote
Old 08-07-2018, 01:54 AM   #6
Hoogah
Hoogah's Avatar
Is this it? https://www.ebay.com/itm/Kano-Kroil-...0AAOSwOBBbT34h
Old 08-07-2018, 08:00 AM   #7
brokenspoke
Slip plate paint is what I use
brokenspoke is offline   Reply With Quote
Old 08-07-2018, 08:14 AM   #8
katy
katy's Avatar
They used to make a tool for spreading the leaves:
Old 08-07-2018, 09:34 AM   #9
Tacoma Bob
Tacoma Bob's Avatar
No...That appears to be their"flagship" product. Penophyte is their product for applying to assembled spring packs. Hope this helps.
Old 08-07-2018, 11:29 AM   #10
Purdy Swoft
Purdy Swoft's Avatar
If a person is running without shocks , it is probably best not to oil the springs or it will bounce real bad .
Old 08-07-2018, 11:57 AM   #11
jb-ob
Hoogha,
With the car supported with jack stands under the frame, wheels off, and a floor jack under the front end, lower the front end as far as the shocks will allow. With the weight off the front end, the spring will relax and easy to squirt your favorite lube between the leaves. This is also the best time to grease king pins and shackles.
Same technique works for the rear.
JB
jb-ob is offline   Reply With Quote
