04-11-2013, 07:24 AM | #21 |
Re: 32 Ford Pickup Sheetmetal Work !
OH! You used the North Dakota radius......great choice!!
On a more serious note.....great work Tom!!! |
04-18-2013, 07:14 AM | #22 |
thanks Jim!!
Story of my life as of late...drill out rivets!!! it seems the cab corners were bashed in on purpose .. kinda weird ! drill spots welds out of the 33 firewall these brackets are going to need to be removed and put back in for the new /old firewall
Please call or email while website is down! 412 867 1659 [email protected] https://www.facebook.com/flop.custom |
04-23-2013, 05:26 PM | #23 |
33 firewalls in !
messy pillar after years of use and abuse nothing is coming easy on this truck old and ugly tacks ended up replacing the whole edge door is hanging also made a corner up for the truck
04-24-2013, 08:34 PM | #24 |
Beautiful Work. Can't wait to see the next pickup you work on !
05-25-2013, 08:10 PM | #25 |
your truck is coming soon John!!
well i have been fighting this truck for a while with measurements . thanks hotrodprimer for some measurements and Carter for stopping by today to take a look! door is hitting the subrail not allowing it to close what i now believe to be the root of all evil for the door not fitting hard to see the more serious damage but the center of the area is sunk in a bunch
05-26-2013, 08:32 AM | #26 |
05-27-2013, 01:25 AM | #27 |
How did you join the new piece in the pillar without making those tack welds that you removed? No visible means of spot welding which is all i know.
<Link> This is how we roll<Link> "I'm Convinced that no one really reads posts anymore; they just fabricate what they think the post says then ramble on about red herrings."--Bob Outcasts rules of old cars #1 Fun is imperative, mainstream is overrated #2 If they think it is impossible, prove them wrong #3 If the science says it impossible you are not being creative enough. #4 No shame in recreating something you never had #5 If it were not for the law & physics you would be unstoppable |
07-08-2013, 09:12 PM | #28 |
robert i like to blast after to test my work . blasting is gonna blow through any weak spots that i do not want to show their heads later on down the line !
there are tiny spot welds there dumb the problem in the b pilar! that should be a circle you can see how much it was bashed in and the crappy door gap hard to see but a short video of the whole pillar moving and after the removal of the smashed subframe and bracing
07-09-2013, 12:25 PM | #29 |
I see your logic....and after my own welding, I blast it again.....epoxy primer holds forever on the freshly blasted metal. Robert
07-09-2013, 11:00 PM | #30 |
Very nice work Flop!
10-16-2013, 10:07 AM | #31 |
finally back in to it after a broken arm
well i made a new subframe corner had t make 12 inches of the B pillar the new corner and a new triangle brace due to some one bashing the hell out of this truck same with the passenger side now the cab is finally untweaked and the door fits as they are supposed to
10-16-2013, 10:29 AM | #32 |
Welcome back!!
Don't never get rid of nuthin! |
10-16-2013, 10:30 AM | #33 |
Flop,
Nice work! Missed you at the ROG.
She just don't have the appetite For gas somehow, And Dad, I got four carburetors Hooked up on it now. I tried to hook another To see if I'd do a little good, But ain't no place to put it 'Less I perforate the hood. Wanted, lower side sections of 32 radiator cowl. |
10-16-2013, 10:36 AM | #34 |
Just saw this over on the hamb. Man you do good work.
10-16-2013, 12:16 PM | #35 |
Awesome work as always Flop.
Followed several of your threads both here and on the HAMB and you never disappoint. Paul. |
10-16-2013, 06:01 PM | #36 |
The doors look alot better..nice job.
10-16-2013, 07:01 PM | #37 |
Glad that you're healed up and back at workin' the magic.
10-17-2013, 09:57 AM | #38 |
Fabulous work Flop Thanks for sharing.
Early Ford Lock & Key Service https://www.fordbarn.com/forum/showthread.php?t=46583 |
10-17-2013, 10:49 AM | #39 |
