05-23-2016, 01:52 PM | #1 |
Carb bolt pattern on a Merc inake
Have 2 1949 -- 53 Merc engines and one intake carb bolt pattern has 3 bolts and the other has a 4 bolt pattern, what does this mean ---Thanks[B][B]]
05-23-2016, 01:58 PM | #2 |
Re: Carb bolt pattern on a Merc inake
The 3-bolt is a Ford manifold. The 4-bolt is Merc. DD
05-23-2016, 02:40 PM | #3 |
Canadian Merc. pickup truck for the 3 bolt ??
05-23-2016, 03:32 PM | #4 |
the merc 4 bolt had a weird looking carb ,I think it was called a teapot carb. I have one taken off a running merc engine , also I think the rochester GM 2bbl should fit on that manifold also. hope this helps.
05-23-2016, 04:12 PM | #5 |
Rochester 2G or 2GC GM 2bbl will fit. Both are good carbs. With an adapter an Autolite 2100 or Motorcraft 2150 will also fit. All are good carbs.
Proud FNG We fixem cars. Heap Good! Last edited by jack orchard; 05-23-2016 at 04:33 PM. Reason: correct speeling |
05-23-2016, 06:00 PM | #6 |
05-23-2016, 09:17 PM | #7 |
I've got a couple of those teapots, free to anyone looking for one.
05-24-2016, 03:03 AM | #8 |
Ralph, bring them down next time you come through Wasilla, I can use them for parts for my 51 Merc. , I am still running that style carb on it. I got back from Texas about 2 weeks ago. still getting back in the "groove" up here. had the coupe out last weekend.-----Jim
