Old 11-23-2023, 07:46 PM   #1
tjm73
Default OEM '32 Tail Light Mounts
I bought a '32 Tudor recently. It's an older stock restoration but has been updated with juice brakes. I was checking things out again after I got it home and noticed that the driver side tail light mount appears to have been repaired at some point. Looking more closely at both the driver and passenger mount it looks like they are cast mounts. All the replacement mounts I see online are sheet metal. Where the original mounts cast? I've tried looking around with no luck confirming they were or were not.
tjm73 is offline   Reply With Quote
Old 11-23-2023, 08:58 PM   #2
DavidG
DavidG's Avatar
Default Re: OEM '32 Tail Light Mounts
The originals were made of formed sheet steel. The cast brackets were aftermarket replacements from decades ago.
Old 11-23-2023, 09:25 PM   #3
tjm73
Interesting. Thank you for the info. Don't know how I would have ever figured that out.
Old 11-24-2023, 05:33 PM   #4
alchemy
alchemy's Avatar
If you require real Fords, make sure the tube portion has a little taper as it goes up. The repros are straight diameter tube.
And the right side original mount will be very hard to find.
alchemy is offline   Reply With Quote
Old 11-24-2023, 06:06 PM   #5
tjm73
I don't need originals. My car is not perfectly stock and will not remain perfectly stock. Mostly stock but mild mods are on the horizon. Think lightly hot rodded as would have been done in the 50's. Nothing irreversible.
I just wanted to locate a cast driver side mount if they were cast OE since mine had been repaired. Now that I know that cast units are not OE, I am not concerned with that.
The CW Moss repops look like they are may be tapered. But even if they are not, that's not a deal breaker for me.
https://cwmoss.com/collections/v8/pr...r-left#details
Old 11-25-2023, 12:42 AM   #6
deuce lover
deuce lover's Avatar
The Drake repos are spot on and tapered.
deuce lover is offline   Reply With Quote
Old 11-25-2023, 02:22 AM   #7
DavidG
DavidG's Avatar
With respect, the current Drake brackets are the same as those offered by C.W. Moss and others and they are not exact copies of the originals. The holes for attaching the bracket to the back end of the chassis frame are elongated whereas on the original brackets those holes are round. Otherwise, they are good reproductions.
Old 11-25-2023, 06:10 AM   #8
deuce lover
Old 11-25-2023, 03:23 PM   #9
F1 MIKE
F1 MIKE's Avatar
The Cast Tail Lamp R-L mounts i have were made by FOLITE CO. The name was cast into them I have a pair on my 32 3W.
F1 MIKE is offline   Reply With Quote
Old 11-25-2023, 04:28 PM   #10
Krylon32
I have black Drakes on the back of my 3 window and sedan. have used several sets in the past, while not 100% authentic they look good to me.
Krylon32 is offline   Reply With Quote
