#1 |
Have a freshly rebuilt crab cap distributor.
Sounds as though there's a noisy bushing scenario in it. Car runs fine, it's just an annoying noise. Does this sound like something possible? What to do? I may pull it off and throw the old on to make 100% certain it is the distributor, but by listening with a stethoscope it seems targeted to the new unit. Thanks |
#2 |
I had a noisy helmet type on the 33,was a rust mark on the advance disc.
lawrie |
#3 |
fresh rebuilt....send it back to the rebuilders if you think you have a bad bushing. Did you lube the rear bushing before you installed it? I would guess the rebuilder did not consider this noise an issue.
#4 |
And make sure the cap and rotor isnt hitting a little bit........
#5 |
Leaky vac brake piston/cylinder can make some pretty strange noises.Try pinching off (rubber hose)or disconnecting the vacuum line and see if the noise stops.
#6 |
I unscrewed the hard vacuum line at the distributor and unattached it. Fired the motor and it was pleasantly quiet. Screwed it back in and it is annoyingly noisy. What next? |
#7 | |
![]() Quote:
I have had a couple squeaking/squealing vacuum pistons over the years.... If that dont work send it back and i will redo it with a different case the day i recieve it,,,,,, |
#8 |
You could grease the piston but it'll only work for a while.Other than that,switch cases or send it back to the rebuilder.The problem sounds like a worn vac brake piston or cylinder.I'm not the greatest mechanic....just speaking from experience.
