01-23-2016, 01:22 PM | #1 |
1939 - 48 rear E-Brakes
Question - Do the 1946-48 Ford cars use the exact same rear E-Brake hardware (stamped metal "arm" and "linkage") as do the 1939-41 Ford cars? If they are not exactly the same/interchangeable would someone please post a photo of the 1946-48 arm and linkage? Thanks
01-23-2016, 01:52 PM | #2 |
Re: 1939 - 48 rear E-Brakes
I have only seen one style e brake hardware. The shoes are different 39-41 from 42-48, in their mounting and adjustment design. Lower part of shoe.
01-23-2016, 02:09 PM | #3 |
The Green Book list one part number for 39-45 and a different number for 46-48. So they are different. The 46-48 are part # 51A 2103 & 2104. The earlier ones are 91A.
01-23-2016, 02:28 PM | #4 |
Other then a part number change , whats different? They look the same on the early and late brakes I have
01-23-2016, 02:36 PM | #5 |
The bottom of the long lever where the cable attaches is off set and not centered.
01-23-2016, 03:33 PM | #6 |
01-23-2016, 03:34 PM | #7 |
You can check all of this in the Green Book. They are listed as the same part # 39-48 91A.
