08-11-2019, 07:13 PM | #1 |
H-10 Two rib spark plugs?
What years and application were these used for?
08-11-2019, 07:32 PM | #2 |
Re: H-10 Two rib spark plugs?
'39 - '40 Ford for certain. Perhaps others as well.
08-11-2019, 08:26 PM | #3 |
They will work in my 48 V12 Lincoln.
08-11-2019, 11:45 PM | #4 |
I "believe" They two rib plugs were used 1938 (late) through 1946 (Early) maybe a expert will chime in and correct me if wrong.
08-12-2019, 09:37 AM | #5 |
The H-10 2 rib was supplied up to WWII. By the end of the war most applications used the 5-rib design. The H-10 was used on many automotive and non-automotive applications, including lawn mowers etc up till present day.
08-12-2019, 10:27 AM | #6 |
08-13-2019, 01:11 AM | #7 |
These plugs are sought after for 'Dearborn' Cars on the judging field. They can get expensive and are often saved just for judging the V8's. A controversy about replaceable parts Vs as built exists. Newc
