Old 01-07-2021, 10:31 PM   #1
fordor41
fordor41's Avatar
Default 2 speed fordomatic
Am going to do some work on my trans and read a few articles that the fluid filter needs to be only washed out and not replaced. Any thoughts?
fordor41 is offline   Reply With Quote
Old 01-08-2021, 06:38 AM   #2
darrell
Default Re: 2 speed fordomatic
other ford transmissions use a screen filter.you just wash it out i would think these are the same.
darrell is offline   Reply With Quote
Old 01-08-2021, 12:30 PM   #3
dmsfrr
dmsfrr's Avatar
I'd expect the procedure to be described in a Shop manual or Motor's manual that covers the year of the transmission.
Old 01-08-2021, 05:29 PM   #4
scicala
scicala's Avatar
If you're going to pull the pan anyway, then I guess it will answer the question. It would be nice to know ahead of time though.
Sal
scicala is offline   Reply With Quote
Old 01-08-2021, 08:18 PM   #5
wbedwards
wbedwards's Avatar
its just a screen, in fact the manual says you can filter and re-use the fluid
wbedwards is offline   Reply With Quote
Old 01-10-2021, 11:36 PM   #6
fordor41
fordor41's Avatar
I have a '60 FOMOCO manual and after a lot of searching I found out to just wash out. Thanks for the info.
