11-17-2019, 04:06 AM | #11 | |
Re: y-block blow by..
The 1960 up FYB PCV design is adequate (IMO) for the engine. There is a baffle on the underneath of the valley pan to direct air flow to the cylinder heads. You would also have to fabricate baffles for the rocker covers with the later design. If the late OEM System is installed correctly, evacuation should be more than adequate, again IMO.
***** We should have a contest. The player has to start at the very last post of a thread & then try to guess what the OP's original question was about ... |
