06-02-2011, 03:25 PM | #1 |
Rear hub removal-one that does not want to come off.
I am trying to get one of my rear hubs off. I do not have the Wilson or other "official" Model A hub removal tool. I am using a three prong puller. Have put the axle nut on backward and put a "spacer" in between the axle and the puller shaft. Tightened it down, but the thing will not come off!
Any suggestions besides buying a $100+ puller? Will a little heat work? A bigger hammer(to tap on it)? Etc.?????? Any good advise would be appriciated. Thanks
06-02-2011, 03:29 PM | #2 |
Re: Rear hub removal-one that does not want to come off.
My only suggestion (which I do not like) is to give the axle nut a substantial knock with a reasonably heavy hammer while under load with the puller, if you can get a hammer near it.
R.H.D. Author of Model 'A' Ford technical manuals. Supplier of good original RHD parts. |
06-02-2011, 03:38 PM | #3 |
I do not recommend going past "Scary" when tightening a 3-leg puller! On the worst
"A" hub I ever encountered, I used a 3-legger even though I own some better alternatives. After moving on to "terrifying" on the torque scale, I heard a loud BANG! and found the (fortunately, junk) drum split! I did not check, but I would assume hub was warped by that point. I would borrow, buy, or steal one of the several types that pulls from central part of hub. |
06-02-2011, 04:10 PM | #4 |
You can reinstall the axle nut, but leave it a few threads loose, then put the wheel back on and drive around the block. This will often loosen the taper.
06-02-2011, 04:22 PM | #5 |
Fred, did you loosen up the brake adjustment on that wheel and release the E-brake. Tighten up the puller quite tight and then with a 2-3 lb. hammer give the end to the puller shaft a good solid hit but not like you are hitting a home run. If the hub doesn't come off with that treatment, tighten the puller again and try the hammer again. This has worked for me.
06-02-2011, 04:40 PM | #6 | |
This trick worked for me a few weeks ago... Thee-legged puller can warp the drum & hub.... |
06-02-2011, 04:48 PM | #7 |
Either a $100 puller, or, a $200 drum and hub.
06-02-2011, 05:11 PM | #8 |
I haven't used it yet, but I have one of the pullers made by Mitchell. $85 including shipping.
06-02-2011, 05:21 PM | #9 |
Apply heat and use the puller and hammer.
John |
06-02-2011, 06:28 PM | #10 |
See if your local Model A (or EFV8) club has one to loan (or maybe rent to a non member).
Charlie Stephens |
06-02-2011, 06:53 PM | #11 |
Thanks guys. I got it off! Used a bigger hammer to tap all the way around it, tightened the puller, tapped it on on the shaft end a few times and off it came.
Lindy, I did have to turn off the brake adjustment to be able to get it all the way off. Charlie I did think about our club but I would have to drive about 50 miles to pick up a tool. With the price of gas, I thought I would "hammer away" at it Again thanks for the thoughts guys.
