11-20-2019, 07:04 AM | #1 |
Remove/Replace Headlight Reflector
I am probably overlooking the obvious, but I didn't want to force anything - how do you remove the headlight reflectors from the headlight bucket?
11-20-2019, 07:33 AM | #2 |
Re: Remove/Replace Headlight Reflector
Open lens cover, remove bulbs, gently pull reflector bucket forwards it will slide right out.
11-20-2019, 08:30 AM | #3 |
Thanks for the fast reply, I will give it a shot!
11-20-2019, 09:28 AM | #4 |
A little closer look will reveal that at the 3 & 9 o'clock positions are small tabs at the front edge of the bucket that hold the reflector in, The reflector should just slide off the bulb socket (the socket is notched to index the bulb filaments).
11-20-2019, 09:39 AM | #5 |
If your socket is corroded to the reflector, you can undo and remove the "focus screw" at the back of the bucket. This will at least allow you to access the back side of the bucket, potentially snip the wires for removal, or demounting the "plug" remove the entire assembly with the bulb socket in place.
A lot of "weathered" buckets have the 3 & 9 tits corroded off - and a corresponding ring of rust making a "rust joint" between the reflector cork gasket and the bucket. A utility knife can knife this and free the reflector. If you're to this point you probably want to get new reflectors anyway with new gaskets. Joe K
Shudda kept the horse. |
11-20-2019, 10:56 AM | #6 |
11-20-2019, 11:26 AM | #7 |
I just push the reflector to one side to release from the tab if needed or just pop it out. The tabs are there to keep it from rotating. The original reflector had the socket offset by just a little and the tabs keep it centered. You should not need to bend them up.
I know the voices aren't real but damn they have some good ideas! |
11-20-2019, 12:14 PM | #8 |
Thanks, someone had bent these over pretty aggressively in the past but I'm all set now.
11-20-2019, 01:20 PM | #9 |
You didn't ask but I thought I would mention that the best reflectors are available from Bratton's. They invested to have the correct tooling made. I don't know is they have released their product to other Model A suppliers.
Charlie Stephens |
11-20-2019, 01:40 PM | #10 | |
I don't think any vendor has a high quality headlight socket. They can be fiddled with and made pretty decent but if you want good ones maybe call Bert's in Denver and see if they have any originals. |
11-20-2019, 10:03 PM | #11 |
dont forget gasket cork
www.whidbeymodelaclub.com |
11-20-2019, 11:02 PM | #12 |
I bought Bratton's reflectors for both my Model As. What a difference.
1924 Model T Coupe 1928 Model A Roadster 1930 Model A Town Sedan 1939 Deluxe Fordor 1945 pickup 1951 Custom convertible |
