Old 12-27-2022, 05:02 PM   #1
History
History's Avatar
Default Shackles with steel bushings
What do you guys think of the bushings offered at snyders with steel bushings and modern grease zerk? I know it’s not like original but I’m ok with that as long as they perform good. Opinions?
History is offline   Reply With Quote
Old 12-27-2022, 05:26 PM   #2
Oldbluoval
Oldbluoval's Avatar
Default Re: Shackles with steel bushings
They originally had steel bushings. Did not have zerk fittings but they’re better.
As to quality of shackles, Snyder’s usually has “best available “ or will tell the down side if you ask.
Old 12-27-2022, 05:55 PM   #3
Mulletwagon
Mulletwagon's Avatar
Put them in two years ago and they are good. Made off shore but quality is excellent.
Mulletwagon is offline   Reply With Quote
Old 12-27-2022, 06:08 PM   #4
Werner
Werner's Avatar
In this application, the steel bushings are better than non-ferrous metal bearings, e.g. copper-brass-bronze. Because the sliding peripheral speed is low.
Hard impact loads are given here; therefor hard steel is better suited for this.
Werner
Ford Model A, Roadster, 1928
Citroen 11 CV, 1947
Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version
Werner is offline   Reply With Quote
Old 12-28-2022, 07:24 AM   #5
History
History's Avatar
Thanks for replies, I had no idea what bushings were used originally as I’ve never taken any part before. I figured since it was mentioned in the Snyder catalog there might be a difference. Will be ordering new ones from them and you are correct, they (Snyders) will tell you if they aren’t the best. They never treat me like everyone should know the answer, they are super nice and helpful. Thanks again
