11-04-2010, 06:37 AM | #1 |
Battery
I need new battery for my 31 Model A I found one but would like to know if you have to have special battery for the positive ground system? New at this just got my Model A a couple of months ago and will probably be asking some questions about things that might sound dumb so any info will help Thanks guys
11-04-2010, 06:58 AM | #2 |
Re: Battery
Nothing special. a Group 1 battery size will fit. Just hook it up the correct way.
Dick |
11-04-2010, 07:12 AM | #3 |
Re: Battery
There are batterys at Auto Zone that has the battery post on the way your battery should fit.
11-04-2010, 07:24 AM | #4 |
Re: Battery
Pretty much match up what you have size wise. I assume it's under the driver's side. You don't need a fancy one with a lot of cranking amps either. Make sure your cables are good. Just a plain jane one from any auto supply store. By the way, that's sure not a dumb question. You should read some of mine.
Pete |
11-04-2010, 02:50 PM | #5 |
Re: Battery
If your car is a positive ground, make sure you hook up the
cables just the opposite way you would if it were a negative ground. Cable size should be about "0" or 1 gage. Just a plain old six volt group 1 battery will do fine. Jack
Cincinnati, Ohio |
11-04-2010, 04:14 PM | #6 |
Re: Battery
11-04-2010, 07:40 PM | #7 |
Re: Battery
What part number do they use for the battery?
11-04-2010, 07:58 PM | #8 |
Re: Battery
part #1
11-04-2010, 08:04 PM | #9 |
Re: Battery
List of modern part numbers can be found at
https://www.fordbarn.com/forum/showthread.php?t=6523 Battery (6 Vo1t) 7200 Exide |
11-05-2010, 06:38 AM | #10 |
Re: Battery
So I go to autozone and ask for part #1?
Autozone any sells Duralast batteries.
11-05-2010, 08:06 AM | #11 |
Re: Battery
I just bought one at TSC for $60.. They don't make em like they used to,, the last only lasted for 12 years..
11-05-2010, 08:31 AM | #12 |
Re: Battery
While you have the battery out, I suggest that you make sure that you have a clean ground. I like to remove the ground strap annually and clean the connection to the frame. I also recommend a second ground - from the positive terminal to the transmission. Gar Williams
11-05-2010, 08:41 AM | #13 |
Re: Battery
No... ASK FOR A GROUP # ! BATTERY
11-05-2010, 10:53 AM | #14 |
Re: Battery
I think you mean from the Positive terminal to the transmission unless you have wired your system for negative ground. The extra cable is usually put between the ground bolt on the frame and the transmission.
11-05-2010, 10:58 AM | #15 |
Re: Battery
A ground strap from the negative battery post to the the transmission? You have to be kidding! Can you say "fire" or melt-down?"
Unless the electrical system has been changed over to negative post grounds you'll be in for a big surprise when the negative post is connected to the transmission. Just another example of the "great" information that shows up from time to time at this site.! |
11-05-2010, 03:38 PM | #16 |
Re: Battery
OK,
From what I can find, 6v group 1 batteries are found by the following numbers; NAPA - BAT 7244 Exide - 7200 Tractor supply - Com 1 HP (part number 0470506) I think. Autozone - 1-6 volt Any others?
04-10-2011, 08:06 PM | #17 |
Re: Battery
These post are a big help
buying a new battery tomorrow |
04-10-2011, 08:22 PM | #18 |
Re: Battery
Ultrapower #901 - 700 cca, it's a commercial battery and lasts longer than one from the the chain auto supply stores.
Driving old Fords since 1947 |
04-10-2011, 10:37 PM | #19 |
Re: Battery
Who sells them?-
04-11-2011, 06:43 AM | #20 |
Re: Battery
interstate part # 1-VHD cost me $75.95.
i would never use any of those autozone, pepboys chain style store junk batteries. |
