Old 07-03-2019, 08:32 AM   #1
40ford
40ford's Avatar
Default Low Coil Voltage:
I can't understand why I am getting low voltage at coil?I am getting 1.58 with resistor I have mounted now.The resistor I got from Carpenters gave me a 1.98 volt reading.The car cranks and runs ok,but I thought you needed at least 3 volts for good fire?I got over 6 volts going to the resistor so I figured the switch block was ok.This is on a stock 40 with 6 volt system.
40ford is offline   Reply With Quote
Old 07-03-2019, 08:35 AM   #2
JSeery
JSeery's Avatar
Default Re: Low Coil Voltage:
Are you sure your readings are correct? Have you tried a different meter? I would start by verifying the readings.
Old 07-03-2019, 11:11 AM   #3
40ford
40ford's Avatar
Yes,I am sure that reading is correct.I got another resistor to try.Is there a way to check a resistor before installing it in car?Does the reading have anything to do if points are closed or open?Heck I am lost here?
Old 07-03-2019, 12:07 PM   #4
JSeery
JSeery's Avatar
Yes, the points have to be closed. Yes you can check the resistor with the ohms settings on your meter.
Old 07-03-2019, 12:10 PM   #5
flatheadmurre
flatheadmurre's Avatar
If the coil is a different resistence from what it should be you get this kind of errors...
Voltage drop over the resistor is depending on how much current flows through it...if the coil draws less amps then it should reading over resistor goes down to...
Old 07-03-2019, 12:37 PM   #6
JSeery
JSeery's Avatar
Good point, might want to determine the coil resistance first.
Old 07-03-2019, 01:26 PM   #7
G.M.
It will not start with 2.0 volts. The starter pulls
the voltage down even lower. You are not reading
correctly or meter is in wrong scale. G.M.
www.fordcollector.com
