Old 05-17-2020, 08:49 AM   #1
gotthard
gotthard's Avatar
Default model b engine swallows
Hi
I do need some help to adjust the engine of my new model b i got yesturday. the engine starts without troubles and accerates fine in parkposition in the garage. But if you hit the road you better drive with the handgas on the dash. If you accelerate by pushing the gaspedal the engine swallows.
Is there possibly some help in this matter?
greetings from switzerland
gotthard is offline   Reply With Quote
Old 05-17-2020, 11:32 AM   #2
Mike Peters
Mike Peters's Avatar
Default Re: model b engine swallows
After startup, did you advance the spark by pulling down on the left hand lever on your steering column? Or possibly a plugged high speed carburetor jet? Do you have the B carburetor or the A carburetor? Yo should have a b carburetor with the B motor.
Mike Peters is offline   Reply With Quote
Old 05-17-2020, 12:00 PM   #3
Jim/GA
Jim/GA's Avatar
Originally Posted by gotthard View Post
Hi
Welcome!
Engine swallows? Please choose another similar word, like coughs, so that we can better understand.
Which handgas on the dash do you keep your hand on? the round knob on the right?
I have years of experience with these cars. I will gladly fly over to switzerland to teach you how to adjust everything and get it running well.
You buy the ticket for me (from Atlanta, Georgia) and I will fly right over! We can have it humming in a few days and then go drive.
Jim Cannon
"Have a Model A day!"
Old 05-17-2020, 12:59 PM   #4
40 Deluxe
And also a B distributor.
Old 05-17-2020, 01:17 PM   #5
abachman3
abachman3's Avatar
GAV set correctly? Perhaps open the GAV a bit more, or conversly, try it with the GAV nearly closed. One of my model A's prefers the GAV to be closed all the way.
abachman3 is offline   Reply With Quote
Old 05-17-2020, 01:51 PM   #6
1931 flamingo
1931 flamingo's Avatar
Do you have GOOD fuel flow to the pump and then to the carb??? The B's have a fuel pump.
Paul in CT
Old 05-17-2020, 02:29 PM   #7
gotthard
gotthard's Avatar
first of all I appolgize my poor Englisch and thanks for the heip. The engine feels like it ties up on street, probably under load only, because on stand it accelerates just fine, also with the accelerate pedal. The car has no lever to advance the spark. I would gess it is a b carburator, because the car is very original stock. choke is not pulled. there is a throttle knop on the dash and with that I was able to drive the car, but not with accelerator pedal.
Old 05-17-2020, 02:48 PM   #8
Bob C
Is you car a 1932 Model B??
Old 05-17-2020, 02:50 PM   #9
gotthard
gotthard's Avatar
here a pic of the dash
File Type: jpeg 762AD90F-105A-4F6E-97A5-6597B2D94A3F.jpeg (103.0 KB, 140 views)
Old 05-17-2020, 02:51 PM   #10
gotthard
gotthard's Avatar
it is a 32 model b produced in 1934
Old 05-17-2020, 02:57 PM   #11
gotthard
gotthard's Avatar
it is a European car, assembled in denmark
Old 05-17-2020, 05:51 PM   #12
rotorwrench
rotorwrench's Avatar
Acceleration under load requires a bit more fuel than No load on stand. We would need to know if the car has a Zenith carburetor or a European type. The GAV adjustment is part of the choke control on the model A but the B is different. A different carb may have different adjustments than the USA model B with Zenith. The Zenith carb has a power jet tube for acceleration that can sometimes fall out in the bowl.
http://www.fordgarage.com/pages/bpowertube.htm
Old 05-17-2020, 06:58 PM   #13
PalAl
PalAl's Avatar
Originally Posted by Jim/GA View Post
Welcome!
Jim better get two tickets..... you will surely need some one to hand you the proper tools. I am very good at this chore, even wipe them down when done using them. Got a date in mind
PalAl is offline   Reply With Quote
Old 05-19-2020, 04:56 AM   #14
gotthard
gotthard's Avatar
here a picture of the caeburator
File Type: jpg 528DA061-09D3-45F3-BD91-7E4899FCC2CC.jpg (41.0 KB, 98 views)
Old 05-19-2020, 11:18 AM   #15
Jim/GA
Jim/GA's Avatar
here a picture of the carburator
That is the correct carburetor for the Model B.
I suspect that one or more of the jets in the carburetor is plugged up with a bit of dirt. They need to be cleaned out.
The engine can run without a load, but does not have enough fuel for power when driving on the road.
It is also possible that fuel filter is partially plugged with dirt.
Or the fuel pump is defective and not supplying all of the fuel you need to drive and have power. (Model A had no fuel pump; Model B has one.)
I hope this helps.
Jim Cannon
Old 05-20-2020, 04:00 AM   #16
gotthard
gotthard's Avatar
I will clean the jets. Thank you very much for the help!
Old 05-20-2020, 04:56 AM   #17
john charlton
john charlton's Avatar
This car could be a Dagenham product although LHD and assembled in Denmark . If it is a tudor and the door hinges on the back pillar (b post) or suicide door then it is English . If the carburetor has a large "Ford " script on the bowl it is English . More totally useless information from "The Old Country".
John in really lovely hot sunny Suffolk County England .
Old 05-20-2020, 02:25 PM   #18
gotthard
gotthard's Avatar
cleaned everything and put some flange sealant because the a gasket was damaged. now it runs grate! my first longer run was just gorgeous..
thank you all for the help
Old 05-20-2020, 02:30 PM   #19
Jim/GA
Jim/GA's Avatar
Good to hear!
Enjoy your drives.
Jim Cannon
