Old 01-15-2019, 05:05 PM   #21
kimeccles
kimeccles's Avatar
Default Re: Ignition, way of
If you want some excellent shocks that look close to original, but are sealed and very well made, consider Stipe Shocks at the link below. I had mine tested and they came very close to original specs. Not cheap, but really good. If you want originals, that will be a bigger challenge.
http://specialtymotorcams.com/shop.php
68B frame# late May1930, fixed seat, Briggs build plate# & most parts, indicate July, or early Aug. 1930.
kimeccles is offline   Reply With Quote
Old 01-15-2019, 05:30 PM   #22
Werner
Werner's Avatar
Hello Kim,
thank you for the link to Mr. Stipe. Yesterday I contacted him for deliver time and shipment etc.
Beste Gruesse aus Deutschland,
Werner
Ford Model A, Roadster, 1928
Citroen 11 CV, 1947
Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version
Werner is offline   Reply With Quote
Old 01-16-2019, 09:41 AM   #23
Benson
Benson's Avatar
FYI:
Stipe shocks are NOT SEALED ... The plug can be removed and shocks refilled.
At least that is true of the two sets that I bought.
Benson is offline   Reply With Quote
Old 01-16-2019, 09:48 AM   #24
Benson
Benson's Avatar
... deleted duplicate post
Old 01-16-2019, 12:57 PM   #25
kimeccles
kimeccles's Avatar
Benson, Thanks for the clarification.
Yes, I was generalizing. You can add fluid, but they don't leak, so it is "sort of" sealed? They can be adjusted for winter, summer. I like the look and feel of them. A quality product for a 90 year old car.
Old 01-16-2019, 01:05 PM   #26
Werner
Werner's Avatar
Hi,
I think there are 'Simmerings' mounted. I understod there gets no oil outside. These shocks must be leekproof.
Werner
Citroen 11 CV, 1947
Old 01-22-2019, 04:08 PM   #27
Werner
Werner's Avatar
Hello,
Stipe's shocks are on the way.
Ignition; I have the hand lever slightly narrower filed and also the lower limit on the teering. I shortened the connecting rod to the distributor a bit. Now my adjustment is -5 > +35 degrees. I think, that is enough.
Not really true, but it's a solvent.
Thanks at all for the helping hints!
Werner
Citroen 11 CV, 1947
Old 01-26-2019, 03:00 PM   #28
Werner
Werner's Avatar
Hello,
I have now solved the problem unusually. The previous adjustment also went with tricks (rod angle) not exceeding 30 °.
Now I have on the hand lever the lower downend to the stop plate filed a little slimmer. And also the stop plate ground down a bit.
Now I have an adjustment of about -5 to +35 degrees.
Thank you for the helping hints to the ignition adjustment by hand!
Werner
Citroen 11 CV, 1947
