Old 01-10-2019, 02:22 PM   #1
springerpete
springerpete's Avatar
Default brake linings
What do you guys use ? I have a terrible squeal problem with my front roadster brakes. Cast iron drums and what appears to be woven linings. It has been suggested that I use molded linings as the so-called woven linings today are not good. My present linings are in good condition but I want to get rid of the noise. Any suggestions on a supplier. Thanks, Bill
springerpete is offline   Reply With Quote
Old 01-10-2019, 02:27 PM   #2
J Franklin
J Franklin's Avatar
Default Re: brake linings
Before you go to the trouble of replacement, try spraying the linings and drum surface with Brakleen, and see if that doesn't stop the noise.
Old 01-10-2019, 03:11 PM   #3
johnbuckley
johnbuckley's Avatar
Try a large worm drive hose clip ( we call them Jubilee Clips over here) around the drum Two hose clips joined together are preferable in fact as they balance better.- This simple dodge has cured many a squealing drum.
johnbuckley is offline   Reply With Quote
