Old 12-12-2018, 12:14 AM   #1
Ntenna
Ntenna's Avatar
Default Firewall mystery
I’m refreshing an older restoration of a ‘30 Victoria 190-A. And on the inside firewall directly behind the terminal box I find four 90-degree “L” brackets. Anybody know if these are original and if so, what they were for?
File Type: jpg 064BAD5A-BA49-4277-81C5-DD4901BF6D52.jpg (62.0 KB, 301 views)
Ntenna is offline   Reply With Quote
Old 12-12-2018, 12:34 AM   #2
1930artdeco
1930artdeco's Avatar
Default Re: Firewall mystery
I think they are for cowl light wire routing.
Mike
1930 TownSedan (Briggs)
1957 Country Sedan
1930artdeco is online now   Reply With Quote
Old 12-12-2018, 01:40 AM   #3
Ntenna
Ntenna's Avatar
Years ago, I have a vague memory of a small hardboard box covering the inside hole to the terminal box. But it could be simply that, and nothing more......
Ntenna
Suffolk, VA
[email protected]
Old 12-12-2018, 03:12 PM   #4
Farrell In Vancouver
Farrell In Vancouver's Avatar
Maybe the P/O ran out of washers?
Farrell In Vancouver is offline   Reply With Quote
Old 12-12-2018, 04:57 PM   #5
Gary WA
Gary WA's Avatar
I like the zip tie! Better if it was black!
www.whidbeymodelaclub.com
Old 12-12-2018, 05:14 PM   #6
Dale G.
Dale G.'s Avatar
It is a bracket that holds up the cowl light wire in a loom that runs to the passenger side. There should be bracket on the passenger side bolted to the screw that comes through the hood welt, likewise another bracket on the driver side bolted to the screw that comes through the hood welt also. All three of these brackets have rubber grommets for the loom to keep the loom from eventually chafing down to a bare wire.
Dale G. is offline   Reply With Quote
Old 12-12-2018, 05:54 PM   #7
Mike V. Florida
Mike V. Florida's Avatar
Page 468 of the Service Bulletins top picture
Old 12-14-2018, 11:27 AM   #8
Ntenna
Ntenna's Avatar
Thanks!
Ntenna
Suffolk, VA
[email protected]
Old 12-14-2018, 11:27 AM   #9
Ntenna
Ntenna's Avatar
Thanks for this! J
Ntenna
Suffolk, VA
[email protected]
Old 12-14-2018, 01:14 PM   #10
Ntenna
Ntenna's Avatar
Yep, page 468 in the Service Bulletins confirms this. In a past restoration someone relocated the two outside “L-bracket loom holders” (what else can I call them??) from the cowl lamp mount area to the center. Plus added that real fine tie wrap. You guys are a great resource. Thanks!
Ntenna
Suffolk, VA
[email protected]
