Old 04-10-2016, 04:17 PM   #1
HDowse
HDowse's Avatar
Default Intake manifold gasket
I'll be reinstalling the intake manifold in a few days and want to know if I should put the gasket on dry or coat it with something like copper spray or blue permatex or ??? It took over two hours to scrape, flat sand and check the manifold and block for straightness. It looks good but if I have to take it off again, maybe dressing it would help both with sealing it and the eventual future removal?
Thanks, Hunt
HDowse is offline   Reply With Quote
Old 04-10-2016, 04:28 PM   #2
Walt Dupont--Me.
Walt Dupont--Me.'s Avatar
Default Re: Intake manifold gasket
Coat both side of the gasket with grease, you can usually remove the intake 2-3-4- times. Walt
Old 04-10-2016, 04:41 PM   #3
jrvariel48
jrvariel48's Avatar
2X Grease!
jrvariel48 is offline   Reply With Quote
Old 04-10-2016, 04:46 PM   #4
HDowse
HDowse's Avatar
Got it, makes sense. I should have remembered since I've done that before. Same for the carb and fuel pump?
Old 04-10-2016, 04:47 PM   #5
ford38v8
ford38v8's Avatar
And water pump.
Alan
Old 04-10-2016, 05:55 PM   #6
Lawson Cox
Lawson Cox's Avatar
gasket and grease is what I use on all gaskets.
Old 04-10-2016, 07:27 PM   #7
FlatheadTed
FlatheadTed's Avatar
I use Plumbers rubber Butnol for pumps ,lasts many removals ,Ted
http://www.flatheadted.com
Flathead Ted brake Floaters ,
Old 04-10-2016, 10:14 PM   #8
Talkwrench
Talkwrench's Avatar
Yes. very small amount of grease on carb gaskets in manifold one, just enough to discolour them. I must admit I used Permatex non hardening for the fuel pump and stand.. not a leak.
Old 04-29-2016, 07:26 PM   #9
Gilski
I am replacing mine as well. What kind of grease should I use?
Gil
Gilski is offline   Reply With Quote
Old 04-29-2016, 07:51 PM   #10
JM 35 Sedan
JM 35 Sedan's Avatar
I use a standard chassis lube type grease on my intake and other engine gaskets. I learned my lesson some time ago (probably after reading some of Walt's and Ol Ron's posts) on the difficulties of removing old gaskets that had had various types of sealer applied to both sides of composition head and intake gaskets. What a messy time consuming job that stuff makes when it comes to replacing a gasket.
John
Old 04-30-2016, 01:47 PM   #11
FlatheadTed
As I said use rubber then you don't need to ,but don't over tighten or you'll crack the casting ,.Ted
