03-11-2019, 07:08 AM | #1 |
1932 Ford Roadster project
City:
Knoxville
State:
TN
Price:
29,500.00
Body is original but needs all patches installed. All new Brookville subrails, United Pacific cross braces, floor, and tool tray installed. Cowl is decent and needs lower patches and work on inner A pillar, 1/4's will need all lower patches and wheel wells installed and some straightening. Passenger door is swinging on original hinges and needs lower inner and outer skin replaced. Drivers door is rougher and needs hinge pockets repaired and inner bottom, should probably be skinned from bead down. Original Drivers hinges included. Deck lid is United Pacific and panel above deck and below deck are Brookville. Lower cowl stanchions are original and in good shape. Every part to repair the body is included except the door patches. Firewall is original and is pretty nice other than some pinholes/pitting in feet. Super nice Original 32' Hood Top and 20 louver sides. Original Shell that was filled way back and is rust free. Original 32' V8 Radiator that was modified for SBC (core). Has Original headlight bar modified for hiboy. Gas tank is original 32' but was tank sealed and condition is unknown. Frame is a very nice set of Early "AB" rails with all numbers visible. Original 32' Front crossmember, K member, and 32' rear crossmember. Nice 32' Wishbone, 32' dropped axle, 32-34 spindles with 40' backing plates fitted using Dennis Lacy kit. Front drums have good hubs but are just rollers. 1934' Steering Box with 32' sector housing, mint 32' Drag Link with parts to rebuild. F-1 shock mounts fitted w/ 48' ford deluxe tube shocks. Rear Axle is an original 32' B model that's complete with original 32' rear spring. Decent set of 32' pedals installed, pedal box has some rust. Engine is a 46-48 59AB core that looks clean with no visible cracks but not checked by a machine shop. Has 39 Standard Gen and gen mount fan. nice Original 39 Deluxe Trans with chrome lever. Has original 32' motor mounts and new 32' trans mount with original hub. Full Set of NOS 16" X 4" 40' Ford steel wheels in original burgundy paint with new Coker 7.50-16's and 5.00-16 ribbed blackwalls. There is a lot of parts and probably things I'm missing so please message or call if interested. Car has Clear TN title in my name to original number on frame. $29,500.00 I will sell the Body and Sheet Metal separate. Thanks, Jim 865-805-9381 Here is a link to the build thread on Hamb showing some details For some reason pictures won't load. https://www.jalopyjournal.com/forum....t-rod.1118760/ |
