Old 07-31-2019, 11:36 AM   #1
fundytides
fundytides's Avatar
Default 31 Standard Roadster Windshield Frame
Just recently a picture of a closed car windshield frame was posted that showed the proper locations for all of the holes. Does anyone have anything similar for the 31 std. roadster. I am repairing a frame that has had some extra holes drilled and want to make sure I have it right. The car was equipped with a vacuum wiper motor.
fundytides is offline   Reply With Quote
Old 07-31-2019, 01:06 PM   #2
Keith True
Keith True's Avatar
Default Re: 31 Standard Roadster Windshield Frame
The wiper motor does not bolt to the frame on that car.It has two pinch clamps that hold it in place.Even the vacuum line to it has a couple of friction clamps to hold it in place.The only holes that should be in that frame are the ones for the snaps to hold the top fabric in place.
Keith True is offline   Reply With Quote
Old 07-31-2019, 01:13 PM   #3
Mike Peters
Mike Peters's Avatar
Keith True's Avatar
Yes. Plus two holes in the bottom frame for finger pulls.
Mike Peters is offline   Reply With Quote
Old 07-31-2019, 02:09 PM   #4
California Travieso
Send a message via Yahoo to California Travieso
Mike,
What distance from the edges are the holes for the pulls? I bought a frame that didn’t have the holes drilled.
David Serrano
California Travieso is offline   Reply With Quote
Old 07-31-2019, 02:10 PM   #5
fundytides
fundytides's Avatar
OK. I think someone drilled a hole to put a mismatched motor on with the shaft going through the frame so I'll get rid of that. The finger pull holes are ok. Are the holes for the top snaps evenly spaced or are there a couple of odd ones near the wiper motor.
Old 07-31-2019, 04:51 PM   #6
Mike Peters
Mike,
David Serrano
California Travieso is offline Report Post
Dave: Finger pulls are 11 inches from the outside edges to the center of the hole. . Countersunk on the outside. I measured both a standard and deluxe window frame, and they are the same.
Old 07-31-2019, 05:18 PM   #7
Mike Peters
fundytides is offline Report Post
Fundy: I looked at an original frame I have and there are five snaps for the top flap. So, from the left side facing the car from the front, the distances are respectively, 1 1/4", 10 1'4", 10 1/2", 10 1'2", 10 1/4", and 1 14" to the opposite side.
Yes, and any extra holes were for the wrong wiper motor, so can be filled. mike
Old 07-31-2019, 05:20 PM   #8
California Travieso
Thanks Mike.
David serrano
Old 07-31-2019, 05:43 PM   #9
fundytides
fundytides's Avatar
Thanks Mike. According to Bratton's catalog, there are 6 snaps.
Old 07-31-2019, 08:47 PM   #10
Mike Peters
Fundy. If your look close, you can just barely make out the five snaps on this car. Like yours, someone has drilled an extra hole for the wrong wiper motor! Five snaps is plenty to hold the front flap in place. Maybe some cars did have six snaps, but this one here did not.
mike
Old 07-31-2019, 09:01 PM   #11
fundytides
fundytides's Avatar
Sure looks original Mike. I'll look closer at mine tomorrow. Thanks again
Old 08-01-2019, 08:41 AM   #12
fundytides
fundytides's Avatar
mike
Mike, I looked closely at my frame today. As you said, there are 5 original holes at the measurements you specified. I will fill the two other holes and carry on with restoration of the frame. Thanks for your help. Nice to be able to move forward with confidence!
Old 08-01-2019, 01:27 PM   #13
Mike Peters
e
Hi Mike,
Take another look at your frame. You should find an empty hole at the wiper location where your sixth snap has been lost.
Also, if your car is late enough to have had a vacuum wiper, there will be two small holes on the top drivers side for the wiper tube clips.
Marco
Fundy: Marco Tahtras sent me the above PM. Wait, Wait! Don't fill those holes in yet. Marco says there ARE 6 snaps on 31 roadster window frame, as does Brattons. The photo shows the open hole on my windshield about 1 1/2" from a snap. Drilled straight through. It doesn't make sense to have two snaps that close, but who am I to say? Marco is a roadster authority, so I won't take issue with him. And for what it's worth, the windshield frame on our 28 Phaeton Does have six snaps, but that's a different car.
Old 08-01-2019, 01:51 PM   #14
Mike Peters
OK, so here's me eating crow. This standard roadster DOES have six snaps. One on either side of the wiper, which is drilled through the windshield frame. This car was "restored" in 1957, and I use the term restored loosely in this case. Right or wrong, I have no idea. Hopefully Marco will see this and chime in?
Old 08-01-2019, 04:40 PM   #15
fundytides
fundytides's Avatar
OK guys, the plot thickens! The 2 snaps close to each other do make sense as that's the way it is on my 27 T to allow for a snap on the flap on each side of the wiper. The frame on my A roadster had some previous work done on it so the extra hole could have been filled then. I will look to see if I can find any sign of the holes for the vacuum line clips. Also, I may have to drill a new hole for the wiper shaft as right now I have 5 snap holes only plus the 2 at the bottom for the finger pulls.
Old 08-01-2019, 07:14 PM   #16
Keith True
Keith True's Avatar
You don't need a hole for the wiper shaft.The shaft goes over the top,not through the frame.I am not aware of any holes for the hose clips on the frame for the open car,mine has two spring clips that have little U shaped divots in them that the hose rides in.No holes for hose clamps on mine.
Old 08-01-2019, 09:05 PM   #17
Bob C
Page 20-14 of the Standards has pictures of the clamps for the wiper motor and the vacuum hose.
Bob
Old 08-02-2019, 06:31 AM   #18
fundytides
fundytides's Avatar
Bob
Thanks Bob. I have the Judging Standards but somehow I missed the info and pictures about the clips. I need to read the book a few more times. Every time I use it I find something I never knew before.
Old 08-06-2019, 07:08 PM   #19
fundytides
fundytides's Avatar
Thanks to this forum and some input from Walt at Bratton's most of my concerns and questions have been answered. The only outstanding question now is the proper location for the 2 snaps on each side o f the wiper motor. I hole is there but the other has been filled and I would like the measurement from the edge of the frame and/or the distance between these 2 snaps.
