11-05-2016, 01:48 PM | #1 |
38 21 stud rebuild
Rebuilding a 1938 21 stud ford engine.. the engine came with champion #7 spank plugs which need changing. What is a current shark plug I could use in it's place?
It came with two fuel pump push rods each a different length.. Which one does it take the longer or shorter one? Thanks in advance. Melisa |
11-05-2016, 03:07 PM | #2 |
Re: 38 21 stud rebuild
Champion D16,or NSK A6
Pushrod is to suit height of manifold flange that takes the fuel pump mount. If said flange height is about 2" tall, it takes the longer pushrod.
Unfortunately, two half wits don't make a whole wit! Last edited by Brian; 11-09-2016 at 04:48 PM. |
11-05-2016, 03:36 PM | #3 | |
11-05-2016, 04:02 PM | #4 |
