Old 01-16-2019, 03:40 PM   #1
Chuck Dempsey
Chuck Dempsey's Avatar
Default Yet another old car pic.....
Floating around on FaceBook......
Chuck Dempsey is offline   Reply With Quote
Old 01-17-2019, 01:41 PM   #2
burner31
burner31's Avatar
Default Re: Yet another old car pic.....
Cool pic thanks....that's my car
Keith
Shawnee OK
'31 SW 160-B
Old 01-17-2019, 03:14 PM   #3
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
I remember when Chief tore down his drive on ramp & had the Hydraulic Lift installed!! The FIRST in town. We also had the FIRST, Fast Battery Charger, in town along with the only 4 way AMBER flashing signal light.!!! It was a Conoco Fillin' Station, next to the Hardware Store & close to the BEST, GREASY Hamburgers & Fried Okra & Onions!!!
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 01-17-2019, 07:12 PM   #4
Bob from Northport
Bob from Northport's Avatar
Is the Model A in the photo being lifted by the front axle and ????
Bob from Northport
Northport, Michigan
Bob from Northport is offline   Reply With Quote
Old 01-17-2019, 07:34 PM   #5
Chuck Dempsey
Bob - good question. I see some pipes running down the side of the running board, and appear to culminate in a 'box' of some sort opposite the back wheel. I wonder if that box is somehow connected to the rear wheel. Hopefully they weren't putting all of the weight on the rear axle......
Old 01-17-2019, 08:51 PM   #6
w.michael
w.michael's Avatar
The pipes running down the side terminate in a funnel. That is the catch system for the drain oil. Lift the car higher than it is in the picture, then move the funnel and the pipes (the joints in the pipe are not tight) to the correct location to catch the engine oil, transmission oil, or differential oil as it drains out.
W. Michael
w.michael is online now   Reply With Quote
Old 01-17-2019, 08:02 PM   #7
michael a
michael a's Avatar
The old lifts had two rails one down each side and the crossrail on the front and rear and the vehicle was lifted why is the front and rear axle
Sent from my SM-J701M using Tapatalk
michael a is offline   Reply With Quote
Old 01-17-2019, 08:39 PM   #8
BILL WILLIAMSON
They figured out 9 ways to lift them--LOL
Bill W.
Old 01-17-2019, 08:45 PM   #9
Penthode
Penthode's Avatar
Nothing wrong lifting by the rear axle. The old Ford was easy to hoist up!
Penthode is offline   Reply With Quote
Old 01-17-2019, 11:51 PM   #10
holdover
I worked at a gas station in the late 50s and 60s(in Huntington NY) that had one of those rail lifts. It was very stable. There were 4 pcs that hooked onto the rails and slid to whatever position you needed, they had a rod about 24" long so you could adjust them easily. There was a U shaped cup that the front and rear axle slid into, once the weight of the vehicle was on it , it did not move. When I moved down to Virginia in 1975 a local repair shop(Reed's garage) had the very same lift and hook-up, it was like being in a time warp. The owner continued to use the lift with slight modifications for newer cars, until the shop changed hands in 1999. It was replaced with a modern lift.
holdover is offline   Reply With Quote
Old 01-18-2019, 10:45 AM   #11
Chuck Dempsey
W. Micheal - I see what you mean... Thanks!
Old 01-19-2019, 09:53 AM   #12
russcochiolo
russcochiolo's Avatar
Fender skirts anyone?
russcochiolo is offline   Reply With Quote
Old 01-19-2019, 10:01 AM   #13
Bob-A
Bob-A's Avatar
Smile Re: Yet another old car pic.....
Skirts are for women not cars!
Bob-A
Bob-A is offline   Reply With Quote
