09-07-2014, 06:04 AM | #1 |
HELP! Unable To Remove Toploader From Model B Motor
I must be doing something wrong. Can't seem to remove a early Ford top loader from my model B motor. The banger has a V8 top loader adapter bolted to it to accept a 32 V8 3 speed box. I've removed all bolts around the tyranny and she should slide out but she won't budge. What am l doing wrong? Help!
09-07-2014, 06:16 AM | #2 |
Re: HELP! Unable To Remove Toploader From Model B Motor
Chris ,if it won't come with a big hammer,you need a bigger one
09-07-2014, 06:26 AM | #3 |
09-07-2014, 09:42 AM | #4 |
I had that problem once. It turns out some one set the pilot shaft into the flywheel pilot bearing with blue loctite. I had to pry the trans out very slowly using leverage on opposite sides and time. Ultimately the bearing came out of the flywheel still stuck onto the trans shaft.
09-07-2014, 10:35 AM | #5 | |
I mean - what else could it be? The tranny to flywheel interface is all pretty much the same as the Model A - Ford used that same setup into the 1950s. Joe K
Shudda kept the horse. |
09-07-2014, 02:27 PM | #6 |
Paul in CT |
09-07-2014, 05:10 PM | #7 | |
Thanks fellas for your input. I think a little brute forced applied gently might get this thing apart.
09-07-2014, 07:16 PM | #8 |
