Old 11-06-2019, 02:56 PM   #1
unclevinny
Default rebuild T85 tranny
I am rebuilding my T85 and interested in replacing the input shaft flow thru bearing with a sealed bearing. However if it aint in the computer the parts man claims it is not available. Does anybody have a part number or any info where i might find this bearing?? Thanks
unclevinny is offline   Reply With Quote
Old 11-06-2019, 05:04 PM   #2
KULTULZ
KULTULZ's Avatar
Thumbs up Re: rebuild T85 tranny
Do you mean the input shaft bearing (7025 or 7065) as your model does not have the front seal (7A283) and you are concerned with possible contamination?
- WHY IS IT ... -
... that everything you buy in the grocery store is either wrapped in or contained in plastic but the government doesn't want you to carry it out in a plastic bag?
WONDERING IN W(BY GOD)V ...
DIAGNOSED CDO - (OCD In Correct Alphabetical Order)
KULTULZ is offline   Reply With Quote
Old 11-06-2019, 05:50 PM   #3
unclevinny
Default Re: rebuild T85 tranny
Yes i refered to 7065 and i do have a new7A283 so i feel that is is the correct application however i think that bearing is a bit too sloppy and should be replaced I had heard that the new and improved replacement is a sealed bearing so i thought i might try it I am trying tho get rid of any problems I experienced with vibrations just hopeing to cover all the bases Thank you for the comeback have you seen or heard of the replacement being a sealed bearing???? beleiive me i an always use good advice!!
Old 11-06-2019, 06:16 PM   #4
Dobie Gillis
Dobie Gillis's Avatar
Try Mac Van Pelt at Van Pelt Sales. He's THE Ford transmission guru so I think he'd know if there's a sealed bearing available, and if there is he might have it. Just google him. BTW he's a member of this forum and good people.
Often wrong but never in doubt.
Dobie Gillis is offline   Reply With Quote
Old 11-06-2019, 06:22 PM   #5
KULTULZ
KULTULZ's Avatar
Post Re: rebuild T85 tranny
Yeah, VAN PELT or there are BEARING/SEAL specialty stores in most areas.
Be careful as there is a lot of OFF-SHORE JUNK coming through.
- WHY IS IT ... -
Old 11-07-2019, 12:26 PM   #6
rotorwrench
rotorwrench's Avatar
I can see having one that is sealed on one side but I wouldn't want a fully sealed bearing in there. Mac would be the one most likely to have what you need. The overdrive unit has a tendency to share oil with the gearbox side whether you want them to or not. There is a lockout rod that goes through. They use the same oil on both sides anyway.
Old 11-08-2019, 01:07 AM   #7
CrownVic55
CrownVic55's Avatar
Where are you getting your parts? I have a T85 with R 11 OD and want to go thru it before I install it. It looks good inside but I don't have any history on it. Came out of a 57 Ford. Thanks for any info.
Ben
CrownVic55 is offline   Reply With Quote
Old 11-08-2019, 01:34 AM   #8
KULTULZ
KULTULZ's Avatar
TRANS SOURCE - http://www.vanpeltsales.com/FH_web/t...BW-ODparts.htm
- WHY IS IT ... -
Old 11-08-2019, 12:37 PM   #9
unclevinny
I will get ahold of Mac I have had great results with him on a t 86. i understand the r11 oil skaring with the t 85 main case but i am not sure if i can improve the input shaft bearing with a sealed bearing, probably just get a new flow through bearing..... I like the second opinions and learning the best possible rebuild as that dang tranny is too heavy for an old man to pop in and out! I am going to call the manual tranny Guru { Mac V.P.} still value your experience and knowledge. Thanks I'll let ya know what happens!
Old 11-08-2019, 12:37 PM   #10
CrownVic55
CrownVic55's Avatar
Thanks for the info KULTULZ.
