Go Back   The Ford Barn > To The Editors > Questions & Suggestions
Old 09-16-2020, 04:50 PM   #1
tshancock
tshancock's Avatar
Default Fuel gage inopp
I have a 36 Model 68 and i'm having a fuel gauge problem. I have 6 volts at the sender but the fuel gauge still reads empty. Any help would be appreciated.
tshancock is offline   Reply With Quote
Old 09-16-2020, 08:15 PM   #2
49Ragtop
Default Re: Fuel gage inopp
I have a 49 Ford. I can access the fuel gauge sending unit from inside the trunk. I pulled it out and the brass float had sprung a leak and sank, thus the "empty" gauge reading. I Soldered the hole and then put it in hot water (if it bubbles you got a hole) and found another hole and soldered it again. I reinstalled it and now it works perfectly.
49Ragtop is offline   Reply With Quote
Old 09-16-2020, 10:04 PM   #3
redmodelt
redmodelt's Avatar
You need to be asking on the Early V8 forums with questions and replies. This section is for help with the site not car questions. By the way adding too much solder can cause the float to give wrong reading.
Old 09-17-2020, 08:17 AM   #4
tshancock
tshancock's Avatar
Okay, thanks for the reply. I also read where if you ground the wire at the top of the sender to see if the needle on the gauge moves, if it does the gauge is good, sender bad, if it doesn't move the gauge is bad. Is this true?
