09-23-2020, 11:35 PM | #1 |
Blue Coil for Transistor Ignition?
Is the Bosch coil correct for FSI distributor? Thanks: Fred A
09-24-2020, 12:40 PM | #2 |
Re: Blue Coil for Transistor Ignition?
First Street Ignitions calls out their own coil as far as what they prefer but I don't know who makes them. They also sell Flame Thrower coils as well. Their unit seems to be based on the Pertronics system.
Bosch blue and silver coils are good for a standard point ignition system but I don't know about the Pertronics type systems. |
09-24-2020, 01:28 PM | #3 |
I've used the Pertronix flame thrower three OHM coil on my 12 volt model A's for years with good service and more power that I can feel . The black flame thrower coil is rated at 40.000 volts . The blue coil is rated at only 35.000 volts . The flame thrower coil is black ,normal size and is advertised to put out 5000 out more volts than the blue coil . I haven't tried the blue coil but the black flamethrower coil looks just like other replacement coils but makes a noticeable improvement in quick starts and power . The flame thrower coil has worked well with original style points for me .
09-25-2020, 10:02 AM | #4 |
I was asking about the blue coil because I have a couple of 30 year olds from my Porsche days. I must have burned up the FSI approved coil when the car stalled in my absence and cooked the whole thing. The woman at FSI talked me into a new module with the plate and all was wrong on arrival. She may have known less than I did about the product. Thanks: Fred A
09-25-2020, 11:04 AM | #5 | |
09-25-2020, 05:07 PM | #6 |
09-27-2020, 10:03 AM | #7 |
I use the three OHM version on twelve volt applications . The one point five coil is for six volt applications and if used with twelve volts will need a resistor at the coil connections .
