Old 05-29-2020, 04:10 PM   #1
divcoone
divcoone's Avatar
Default Rear end ???
Just returned from a 80 drive with 0 problems. Went to put the 30 coupe. in the garage and Somethings binding. Car will move forward but binds backing up. I raised the rear wheels off the ground and problem goes away. Has a Mitchell overdrive. ???
divcoone is offline   Reply With Quote
Old 05-30-2020, 12:23 AM   #2
Kurt in NJ
Kurt in NJ's Avatar
Default Re: Rear end ???
possible pinion bearing nuts loose, driving the pinion gear is pushed into the bearing, in reverse it would try to screw itself deeper into the ring gear causing binding
Old 05-30-2020, 06:56 AM   #3
divcoone
divcoone's Avatar
Thanks, I hadn’t thought about that.
