#1 |
I drive a model B 1932 with aftermarket motometer. The motormeter does work on hot wather, but it does not on the car. It looks not as a suprise to me, because the cooling wather level is not visible an level is below the baffle. So there is no contact to the temperature sensor of the motormeter. I wonder how that schould work normally?
To make it a little more complicate, I just bought a calormeter, witch I prefer to install. Also this item works on testrun with hot wather in the kitchen. But this item has a long shaft and therefore I cannot install because there is a conflict with the baffle. Is there any help to solve this problem? |
#2 |
Going to be taller.
#3 |
Can you make a copper extension (to go on the Motometer) that will reach the coolant?
#4 |
the motormeter is designed to read the air above the coolant, and steam, it will show the first little bit of steam that comes before true boiling overheating
#5 |
so I assume it is possibly not a good idea to drill in the baffle, isen‘t it?
#6 |
#7 |
I just found out it comes from a fordson n tractor and it runs in the coolant
#8 |
The short one , take it to a REAL HARDWARE store, if there are any left where you live. You need a spring that will tightly slip over the end of the motometer probe. That will allow the srping to conduct the water temp up to the proble. Be careful when opening the cap, because the spring can fall off it it is too stiff, or too loose fitting.
The long one, there is no answer for that one, without having a custom radiator made up. Although it does look cool. |
#9 |
The original motometers had a different calibration so that they would compensate for the bulb not being in the coolant and give a more accurate reading of the coolant temperature. The red fluid would show above the cap with a lower temperature of the vapor above the coolant. Steam was not needed before the red line showed.
