01-15-2014, 05:07 PM | #21 | |
Re: Drake's 39 pedal assembly
http://www.chtopping.com/rodder96/ Also Chassis Engineering Inc. Part number AS-2021
Ignorance of the laws of physics does not mean they do not apply to you. Last edited by 29AVEE8; 01-15-2014 at 05:22 PM. |
01-15-2014, 05:44 PM | #22 |
Matt, as you know, I'm studying this brake stuff real hard right now. There is a thread somewhere that discusses single vs. dual that is very good info. The consensus on that thread was that a dual was definitely safer IF and only IF it is properly configured. I'll try to find that thread and send it to you.
Also, I might add that a dual master being safer also means adding a booster gets way more complicated should you decide to try that.
Do I look like I have a plan B? |
01-15-2014, 06:12 PM | #23 |
I have been told the Feds outlawed single reservoir master cylinders in the 70's. The weird thing is that NSRA still allows them in their safety 23 inspection. Go with the dual reservoir system, don't take a chance. Master Power Brakes, 888-251-2352 can give you any MC you need and great brake system advice.
01-15-2014, 06:24 PM | #24 |
Matt, call and talk to Ralph at Engineered Components Inc.
01-15-2014, 07:39 PM | #25 |
It's a hot rod. Everything is about risk. Check it, inspect it, and forget it. If a single works without too much hassle, throw it in there. If you can fit a dual without too much hassle, may be good insurance. I wouldn't stress too much about it.
Just b/c it's a dual system, doesn't mean it works all the time. Anyone remember Audi's from the '80's? |
01-15-2014, 09:09 PM | #26 |
Nothing wrong with it except for the name on the front. Alex |
01-16-2014, 05:06 AM | #27 |
Yes dual output, no equalizer was needed, MC was drum/drum set up. Zeke
Only problem with retirement is never a day off |
01-16-2014, 06:48 AM | #28 |
Post #17 above talks about the pedals being cast or forged. Does anyone know for sure whether they are forged? Or cast?
01-16-2014, 08:17 AM | #29 |
Matt, this is the old thread I was speaking of. It has some good info about the workings of a dual master and how to set it up.
https://www.fordbarn.com/forum/showth...ewer+ford+dual
01-16-2014, 01:21 PM | #30 |
Cast pedals versus forged - does it matter on a street car?
Is the quality of the reproduction pedals good enough to trust your life? |
01-16-2014, 02:30 PM | #31 | |
QUOTE] As was noted earlier, if a guy needs to heat, bend and fine-tune the fit of one or both of the pedals on an original forged steel set (which guys do frequently with original '39 pedal sets in NON-'39 cars), that would not be possible with CAST pedals...that's why it matters. DD |
01-16-2014, 07:28 PM | #32 |
Bending pedals is not an concern for me as I bought a 39 frame missing the pedals.
Surely someone has actually bought the repros and has an opinion and/or first hand knowledge if they are indeed cast? |
01-17-2014, 02:39 PM | #33 |
Inquiring minds... our pedal arms are forged.
01-17-2014, 04:04 PM | #34 |
The power of the internet!
Thank you for the clarification. |
