10-02-2011, 07:05 PM | #1 |
Drake's 39 pedal assembly
Bob Drake sells a new 1939 clutch/brake assembly that will take the original single cylinder master cylinder or a dual cylinder. I do not know what the advantage of a dual cylinder over a single is....can someone please explain the differences? Thank-you,...Matt in Alameda
10-02-2011, 07:21 PM | #2 |
Re: Drake's 39 pedal assembly
Matt
It's just to make the front and rear braking systems separate. Same as new cars have been since about 1968. Not too sure it's better, but just my opinion Jim |
10-02-2011, 07:32 PM | #3 |
The whole idea behind a dual master cylinder is to have two independent hydraulic systems. One runs the front brakes; the other runs the rear. In case you develop a leak or failure of any hydraulic component, the probability of both systems losing pressure simultaneously is very low. Unless of course your component failure is the master cylinder in which case you may lose both.
Ultimately, the idea is a theoretically safer braking system. Whether it is better or not is opinion. A well serviced, routinely inspected single master cylinder system works just as well. COE Dan |
10-05-2011, 10:00 PM | #4 | |
I changed down a gear and put my foot on the brake pedal, which went straight to the floor, for anyone who hasn't experienced 'that' I can assure you, it's a heart stopping moment. The Gods were smiling on us as we crossed three lanes of traffic. By using the gears and the handbrake we were able to use the free turn lane, we took the bend fast and then cruised for a block in second gear using as much handbrake as we could. We (and others) were very lucky no-one was in our way, we went through a red light at the next intersection and coasted to a stop on another uphill slope. The mechanic was really perplexed as to why Mitsubishi would use a single cylinder master cylinder especially on a truck, and this was a 1980 vehicle. If you have a choice between a dual and single cylinder I would suggest the dual would obviously be safer. If your choice impacted on a judging decision at a show I would lend my voice to have dual cylinders exempted on safety grounds. |
10-06-2011, 07:39 AM | #5 |
Dual m/c's are like seat belts. They may not have been on your old Ford originally, but it is one of those advances that definitely should be incorporated for safety.
10-06-2011, 07:50 AM | #6 |
10-06-2011, 07:59 AM | #7 |
I had a 59 willys suburban a few years back, Nice old original colorado vehicle. After my fun meter got up to the full mark with it I put it in hemmings. A guy from New Jersey bought it and had a transporter pick it up.My willys was the last car on the back, wouldnt you know, after driving the wheels off on this thing for quite some time, the brake pedal went right to the floor just as I got on to the transporter. Thanks to a good emergency brake and fast fading but still somewhat functional reflexes I managed to hold it right where the driver wanted it,I am sure he cussed me a bunch ,as he had a lot of cars to drop off before mine and said using the emergency was no problem for him. I am glad this didnt happen on the road, what a catastrophy that could have been. A dual system would have been cheap insurance against this, I would never have an old ford without one! Rich.
10-06-2011, 08:27 AM | #8 |
your willys must have been mad that you sold it!
If it would have been a snake it would have bit ya! i can't spell my way out of a paper bag! |
10-06-2011, 08:58 AM | #9 |
I drove a nice 1953 Victoria, as my everyday car, back in the early 70s. One time, while waiting at the bottom of a steep hill, for traffic to pass, My foot, on the brake pedal, went to the floor and I drifted out into the main road. Luckily, for me, it was when the traffic broke. It was the brake fluid line that rusted through.
I will never depend on one cylinder again ! That was scarey ! MIKE |
10-06-2011, 09:21 AM | #10 |
That is why you have an emergency brake,now called parking brake.
"Never complain,never explain"... Henry Ford II |
10-06-2011, 09:38 AM | #11 |
If you decide that you want an original '39 pedal assy, PM me.
10-06-2011, 09:57 AM | #12 | |
i am with you on this one....i had one of those moments in a 1965 chev PU and its not fun..... |
01-15-2014, 03:15 PM | #13 |
I was going to start a new thread but found this one.
I have been looking at cost of acquring and rebuilding a 39 pedal assy versus the new cost of the reproductions. Has anyone used a Drake 1939 brake pedal assy? Satisfied with the quality and fit? Are they the same source as the lower cost eBay clones? |
01-15-2014, 03:32 PM | #14 |
I would check with Richard @ the Early V8 Garage. He has some solid info on dual MCs
Early Ford Lock & Key Service https://www.fordbarn.com/forum/showthread.php?t=46583 |
01-15-2014, 03:45 PM | #15 |
When one of the hydraulic lines rusted out on my 2000 Ranger pick'emup, it was rolling down my driveway. Pedal went nearly to the floor and it stopped. Wouldn't have wanted it to happen in traffic, but the remaining brakes were better than nothing.
Don't never get rid of nuthin! |
01-15-2014, 03:48 PM | #16 |
My question is not about dual master cylinders - totally agree that is the best setup.
Trying to decide on buying the reproduction 39 pedals versus find a swap meet set and deal with rebuilding them. thanks |
01-15-2014, 04:00 PM | #17 |
I have never seen one of the Drake units but I had a question about whether the pedal arms were cast or forged like Henry made them. About third hand anecdotal evidence suggests that the Drake units are cast as I assumed. If you are needing to re contour the clutch pedal for clearance as is sometimes required on an earlier than 1939 chassis, then I think the cast units would not work. Like I said this is not first hand experience.
Ignorance of the laws of physics does not mean they do not apply to you. |
01-15-2014, 04:24 PM | #18 |
Here is a dual cylinder set up. Zeke
Only problem with retirement is never a day off |
01-15-2014, 04:30 PM | #19 |
Did you redrill the MC mounting holes on factory pedals or is the the Drake repro?
Or is there an adapter plate? |
01-15-2014, 04:51 PM | #20 |
Looks like an adapter w/orig 39 pedal assy like what I used in my 36.Finding the bushings to rebuild the 39 pedals was the biggest challenge. I used a dual MC available from NAPA or Amazon($40) that has a 7/8" bore and the ports face the outer frame.Makes a clean install and like having power brakes.
