Old 10-06-2014, 08:49 PM   #1
NealinCA
NealinCA's Avatar
Default Model A vs 32-34 B style Head Gaskets?
Snyders 5.5:1 head says must use 32-34 B style head gasket. What is the difference between a B style head gasket and a Model A style?
We have a Victor 7013 copper gasket, and would like to use if OK.
Neal
NealinCA is offline   Reply With Quote
Old 10-06-2014, 09:42 PM   #2
gwhite
gwhite's Avatar
Default Re: Model A vs 32-34 B style Head Gaskets?
Neal,
The 7014 (Model B) has the extra steam holes and has a slightly different combustion chamber shape...provides more room around the valves than the 7013 (Model A) gasket.
Will see if I can dig up a pic.
Edited to add: The B gasket may also be smaller around the flycuts - could be an issue if you have much in the way of an overbore.
gwhite is offline   Reply With Quote
Old 10-07-2014, 05:18 AM   #3
James Rogers
James Rogers's Avatar
I install probably 30 or more 5.5 heads each year and always use Snyder's Model A copper gasket. The gasket is made by Best Gaskets and is designed for a .125 overbore. Never had a failure.
James Rogers is offline   Reply With Quote
Old 10-07-2014, 07:56 AM   #4
Mike
Mike's Avatar
James,
On a copper gasket seems up or down ?
Mike
Mike is offline   Reply With Quote
Old 10-07-2014, 03:30 PM   #5
James Rogers
Up. If you get any wear from the movement of the gasket, you want it on the head surface. The head can be resurfaced much easier than the block.
Old 10-08-2014, 03:41 PM   #6
hardtimes
hardtimes's Avatar
I second these remarks, as BEST copper, is the best, IMO and experience. I just went out to .125 on a B that is short block now, and that .125 gasket still has a good fit.
I've been wondering if different guys have different/good method to keep gasket IN PLACE and from wondering till head is on I think that gasket moving while installing head, is cause for some of burned/blown head gasket problems..no ? How do you make sure it does NOT move..anyone.
