Old 01-09-2023, 09:14 PM   #1
theriddler56
Send a message via Yahoo to theriddler56
Default Need help
There were some articles on upgrading a banjo axle to modern axles and brakes.
I need help finding the articles. Appreciate any help.
Stephen
theriddler56 is offline   Reply With Quote
Old 01-09-2023, 09:48 PM   #2
Bob C
Default Re: Need help
Something like this? https://www.hotrodworks.com/product/...e-ford-brakes/
Old 01-09-2023, 10:19 PM   #3
petehoovie
petehoovie's Avatar
Originally Posted by Bob C View Post
Old 01-10-2023, 09:53 AM   #4
theriddler56
Yes an upgrade like the one pictured. I am aware of Hot Rod Works setup. There were some articles posted in the past on Ford Barn by members who have done the machining / fabrication themselves, however I can’t seem to find their posts.
Old 01-10-2023, 11:58 AM   #5
Bob C
Here's an article on the HAMB. https://www.jalopyjournal.com/forum/...-axles.380478/
Old 01-10-2023, 05:32 PM   #6
A bones
A bones's Avatar
As I have seen posted by other members, re- post
( since I believe there is no provision to change, edit, a title )
using your need in he heading.
Should bring a quicker response
Kudos to Bob C and Jalopy Journal
Enjoy yer day. Tom
Hate can't fix what it started.
A bones is offline   Reply With Quote
Old 01-10-2023, 09:41 PM   #7
theriddler56
Appreciate the link. I have a question about using the 7.5 Ford axle side gears. They measure 1.74” is there enough meat in the ring gear and differential to remove what’s needed to install them. I understand that Hot Rod Works gear are custom made for this application and measure 1.6” thus leaving more material.
Opinions gratefully appreciated.
Thanks,
Stephen
Old 01-10-2023, 10:16 PM   #8
Ronnieroadster
Ronnieroadster's Avatar
Thanks,
Stephen
Having converted a lot of banjo rears to drop in axles for the street and for the family race car which has run as fast as 229 MPH with our simple back yard conversions. I can help you with some information.
The hot rod works side gears are custom made only in the area where they mesh with the early Ford spider gears. The hub diameter is not special its the same size as the 8 inch and 9 inch Ford side gears. If your idea is to use the 7.5 side gears your going to be in uncharted waters.
Question are you sure the 7.5 side gears will mesh correctly with the Ford banjo spiders?
Never had a need to try them so I'm not sure.
Ronnieroadster
I use the F word a lot no not that word these words Flathead , Focus and Finish.
"Life Member of the Bonneville 200 MPH Club using a Ford Flathead block"
Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline.
First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH
Old 01-10-2023, 10:31 PM   #9
cas3
If you search the hamb you will find many discussions about this topic. In one, JSEARY, whom we have not heard from since June, had some other side gears he was using that he claimed fit as good as the Idaho ones. Sorry, I cant remember what he was using, but jerry was no dummy
Old 01-11-2023, 06:29 PM   #10
40cpe
40cpe's Avatar
I'm reluctant to post this, but JSeery was a frequent contributor here on the 'Barn and I took every post he made to heart. This obituary matches his biography on his profile. It looks like Jerry and his mother and father all passed within a couple of years. My condolences to their family.
https://www.legacy.com/us/obituaries...ry?id=36924557
Old 01-11-2023, 06:34 PM   #11
petehoovie
petehoovie's Avatar
40cpe > "I'm reluctant to post this, but JSeery was a frequent contributor here on the 'Barn and I took every post he made to heart. This obituary matches his biography on his profile. It looks like Jerry and his mother and father all passed within a couple of years. My condolences to their family.
https://www.legacy.com/us/obituaries...ry?id=36924557"
Jerry Seery
1947 - 2022
