Old 03-30-2018, 01:32 PM   #1
jimTN
Default TASCO timing device for Ford V8
Does anyone have a copy of the instruction sheet they could post or send me for this timing device? The one I have is for the early distributors.
jimTN is offline   Reply With Quote
Old 03-30-2018, 01:59 PM   #2
Hoop
Hoop's Avatar
Default Re: TASCO timing device for Ford V8
Is this it? Instructions are included in the link.
https://ingeniumcanada.org/ingenium/...=1999.0150.001
"Remember that when it comes to intelligence, half of all of us are below average."
Hoop is offline   Reply With Quote
Old 03-30-2018, 04:08 PM   #3
jimTN
Hoop, that is the rig but not the instruction sheet. That info is printed on the device itself. There is more to the instructions than what is printed on the face. I went back into previous postings looking for the same info and so far does not seem like it has surfaced.
Old 03-30-2018, 04:52 PM   #4
Hoop
Hoop's Avatar
Jim, the problem with distributor timing fixtures/tools is that so often the user does not understand how the distributor works ... not saying you, but usually.
The instructions on the device explain its operation. However, if you know what you are trying to do, you wouldn't need instructions at all. For example, hammers do not come with instructions ... but if they did, they'd be 3 pages long.
For the Tasco, set both sets of points at .014. Set the pointer on an 8 mark. Move the sliding index on the side of the distributor until the light just goes out. That is the LH points opening and firing the plug.
This sets the dwell and the initial advance. They give the additional step of the light coming back on within the white block. That confirms that the RH points are closing and initiating the proper dwell period which means the light stays lit until the next 8 mark. If the light comes on outside the block, fiddle with the RH points until it does. (RH/LH is as distributor installed viewed from sitting in the front seat.)
Worst instructions are the KR Wilson ... they take 3 steps and condense them into 47. Don't need no stinking instructions.
Really simple stuff that is treated like alchemy.
Old 05-08-2018, 10:40 AM   #5
fryguy
Thanks for the explanation hoop. I was staring at my tasco device today. Most of the face of the device is rubbed off but I do see most of the 8's
Fryguy
fryguy is offline   Reply With Quote
Old 05-08-2018, 11:07 AM   #6
Hoop
Hoop's Avatar
You only need one 8 mark. Unless you have wear/problems, when set at one mark the points should break the same at all 8 marks. Should be easy to remark the worn marks for double-checking.
Old 05-10-2018, 04:33 AM   #7
fordscript
fordscript's Avatar
I have a WASCO timing fixture. But there is no instructions with it. Any of you fellows had any experience with one of these. I guess it will be simple enough, once you know how...
fordscript is offline   Reply With Quote
