12-03-2023, 12:03 AM | #1 |
54 Mercury Front end steering question
This photo shows the steering arm that attaches to the LF brake/backing plate assembly. Is it held on with just the nut and cotter pin? Or is it pressed on and hard to get off. Looking to glass bead it and repaint it.
Bob from Northport Northport, Michigan Last edited by Bob from Northport; 02-05-2024 at 08:22 PM. |
12-03-2023, 03:28 AM | #2 |
Re: 54 Mercury Front end steering question
You mean where it is attached to the tie rod end? You use the same puller you used on the drag link end.
12-03-2023, 09:37 AM | #3 |
I simply unbolted the arm from the backing plate. So I need to use a puller to remove the arm from the tierod end???
Bob from Northport Northport, Michigan |
12-03-2023, 10:12 AM | #4 |
Yes. Remove the castle nut and use the puller.
12-03-2023, 12:34 PM | #5 |
What kind of puller?? I'm used to working on Model A Fords. Everything just comes apart
12-03-2023, 01:11 PM | #6 |
1. Borrow a tie rod tool from your local chain auto parts store: O’Reilly’s, Autozone, Advance Auto 2. Use two good size ball peen hammers, use one to backup the steering arm eye and the other to smack it really hard. I have never been successful with this technique, probably didn’t hit it hard enough. 3. Use a pickle fork. These work, but there is usually some damage to the tie rod end or seal. I would only use the fork if I was planning to replace the tie rod end. Good luck with your project. |
12-03-2023, 05:41 PM | #7 | |
What you have seen here is a demonstration and prime example of ADVANCED CRS on my part. Now I am getting different posters confused ... Read through this thread and it will explain it ... https://www.fordbarn.com/forum/showthread.php?t=333369 Sorry about that ...
***** - WHY IS IT ... - ... that everything you buy in the grocery store is either wrapped in or contained in plastic but the government doesn't want you to carry it out in a plastic bag? WONDERING IN W(BY GOD)V ...
DIAGNOSED CDO - (OCD In Correct Alphabetical Order) |
12-03-2023, 06:43 PM | #8 |
Thank you sir!! I will check my tools and see what I can find. Appreciate the assist
